RHS LS7 Engine Build
Old May 4, 2010 | 07:09 PM
GTII's Avatar
Default RHS LS7 Engine Build
Just started building a LS7 for my Z06. This will be primarily for the track. (Road Course)
RHS Block
Callies Crank with 2" Journals drilled for a ZR1 clutch assembly
LSX-LS7 Heads
ARP Head Studs
Manley Rods
Mahle Pro Series Pistons
LSX 102 Intake
Still have not finalized my cam selection yet.
Old May 4, 2010 | 07:21 PM
99T/ATIME's Avatar
Originally Posted by GTII
[B]Just started building a LS7 for my Z06. This will be primarily for the track.
RHS Block
LSX-LS7 Heads
ARP Head Studs
Manley Rods
LSX 102 Intake
Check the bolt pattern on the crank. I ordered the same thing and it came with an 8 bolt pattern. Arrrrrgggh, they ended up getting me a 6 bolt and I used an aftermarket flywheel with the ZR1 pressure plate.
Old May 4, 2010 | 07:29 PM
GTII's Avatar
Thanks. I followed your build and caught the problem before my crank was built. I'll be getting the proper 9 bolt stock ZR1 flange pattern. How do you like the clutch in your car?
Old May 4, 2010 | 07:35 PM
98Z28CobraKiller's Avatar
Restricted User
Nice build. Are those LSX LS7 heads actually available yet?
Old May 4, 2010 | 07:50 PM
99T/ATIME's Avatar
I love it, it's the best clutch I've ever felt. I haven't beat on the car yet, except for some 160 mph runs, but it seems to hold the power no problem.
Old May 4, 2010 | 08:14 PM
GTII's Avatar
Yes .... I have had mine for about a month now.
Old May 4, 2010 | 08:21 PM
fuel's Avatar
how much where thoes...and what are the valve size
Old May 4, 2010 | 08:35 PM
GTII's Avatar
2.200" Titanium Intake
1.610" Sodium-filled Exhaust
I believe this is the same as a stock LS7.
This casting takes advantage of the extra head bolt pattern in the RHS block. the casting is also stronger. It has room for porting, but I don't see a lot of horsepower gains on this size engine with say a torquer type cam with a redline of @ 7000 rpm.
They cost me @ $1200.00 each
Old May 4, 2010 | 08:40 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
what is also nice about these heads that are most of the company that offer a cnc porting program for the OE ls7's will most likely work for the gm performance ls7 heads
Old May 4, 2010 | 08:57 PM
GTII's Avatar
Here is a pic of the Piston
Old May 4, 2010 | 09:43 PM
fuel's Avatar
did you buy them through gmpp
Old May 5, 2010 | 02:56 AM
GTII's Avatar
Yes ...... part # 19201806
Old May 5, 2010 | 02:59 AM
GTII's Avatar
I agree .... I may try and have them CNC ported at some time in the future.
Old May 5, 2010 | 06:30 AM
SweetS10V8's Avatar
What size engine are you building?
Old May 5, 2010 | 07:46 AM
fuel's Avatar
do those heads have pedistols or does it have a flat aera ffor the rockers
Old May 5, 2010 | 03:40 PM
Jimbo1367's Avatar
Old May 8, 2010 | 06:00 PM
Philip@HPE's Avatar
Man this looks like it's gonna be a sweet setup. What cams are you looking at?
Old May 8, 2010 | 06:47 PM
Busted Knuckles's Avatar
I I haven't beat on the car yet, except for some 160 mph runs
Glad to hear you're taking it easy...
Old May 11, 2010 | 10:30 AM
Steve1969LS1's Avatar
My RHS block just arrived.. it's a beautiful piece!
Sounds like a killer build.. I will be doing a 460 with mine (4.155/4.250)
Old May 11, 2010 | 10:43 AM
ATVracr's Avatar
Tall deck I hope.
We are doing the same with a 4.25 crank.
