Interchangable 5.3L and LS1 parts?
Old May 15, 2010 | 10:40 AM
novaboy7272's Avatar
Default Interchangable 5.3L and LS1 parts?
Ok i was wondering if essentially the 5.3 crank and rods could be used to potentially create a cubic-inch numbers correct LS1 if the 5.3 block was bored to match the 3.90x LS1 bore pistons. I know that is probably the max for boring out those 5.3L but can my 5.3L crank and rods be used with the LS1 pistons? Thanks guys
Old May 15, 2010 | 06:50 PM
SREETRACEGUY's Avatar
the 5.3 can be worked into a 5.7 however if you swap the 5.3 pistons with the 4.3 or whatever thee smallest V8 is it will give you higher compression like around 11.0 i think
