Technical Question: Why LSX block can go to 4.2" bore while the LQ9 can not???
Old 05-15-2010, 04:40 PM
LS6
LS6's Avatar
Default Technical Question: Why LSX block can go to 4.2" bore while the LQ9 can not???
I have this question which I didn't find the convensing answer:
Through reading about the LSX block, it has the ability to go all the way up to 4.2" bore and still able to with stand high power application, while the LQ9 block can maximum be bored up to 4.065". Why is this the case while both block have almost the same dimensions, cylinder to cylinder call thinkness is the same, thus why the LQ9 can not be bored to 4.2"?
The only answer I think is that the material of the LSX block is been constructed from a material having higher strength properties (yield & tensile strength) than the LQ9 block!!!
Please advice???
Old 05-15-2010, 05:44 PM
Nitroused383's Avatar
Think about water jackets...
Old 05-15-2010, 08:15 PM
SPDMETL's Avatar
A machinist might be able to bore it to 4.200, but it would be tinfoil. You'd wind up pretty pissed !
Old 05-16-2010, 03:14 AM
FRUSTRATED T/A's Avatar
I think the max max is 4.080, iv always thought about the same thing. What is the real limiting factor. I know a sonic check is in order when going way over, mybe the lsx is a more true cast also. I do believe i read they are of stronger iron. I know the deck height is higher. I always figured it would be bore spacing limited. Havnt looked at one real close apart in a long time thou.
Old 05-16-2010, 01:33 PM
LS6
LS6's Avatar
is it possible to bore to 4.1" with no issue
Old 05-16-2010, 06:45 PM
supermouse4's Avatar
Probably the reason why the LQ9/LQ4 block can't go to 4.2" bore is due to water jackets. More than likely with a huge overbore, it would hit a water jacket and then you're SOL. The LSX has more material to machine away, but I'd always stay with having the cylinder walls with a thickness of 0.25" to be safe. For an LQ9 block, I'd go with a max overbore of 4.06" if you are running NA, 4.03" with nitrous/blower/turbo application for safety.
The LSX iron is much tougher than the LQ9 block, but it all depends on what you want to build with it.
Old 05-16-2010, 08:46 PM
427's Avatar
The LQ9 block has water between the cylinders in the casting, the LSX is solid between the cylinders like the LS2 or LS7.
Kurt
Old 05-21-2010, 05:13 AM
LS6
LS6's Avatar
thus the maximum to go with is 0.065"
Old 05-21-2010, 01:38 PM
NemeSS's Avatar
mine is at .060 now
Old 05-21-2010, 05:30 PM
racer7088's Avatar
Cylinders are way thicker on LSX and it's siamesed like Kurt says with solid metal between the bores.
Old 05-22-2010, 10:47 AM
LS6
LS6's Avatar
This is indeed a significant factor for LSX block...
Quick Reply: Technical Question: Why LSX block can go to 4.2" bore while the LQ9 can not???
