Really torn between N/A (+n2o) and blower
Old May 19, 2010 | 02:00 AM
pHEnomIC's Avatar
Default Really torn between N/A (+n2o) and blower
I recently threw a 404 ls2 in my car. I have torquer v3, stock ls1 heads,ls6 intake, t-56, building an 8.8 rearend for it. Full suspension and odds and ends.
I already have a 150 wet kit for the car and its installed with full accessories.
Basically I want to finish up my car and that would require either going h/c/i or throwing a supercharger on it. I plan on finishing up this rearend this summer and getting a driveshaft for it so i can start to launch hard.
Goals were originally to just run an 11.9 (best was 12.1@127 on old engine with 100 shot and street tires), i should be able to run well past it with this setup no problem. I just want a sick street car that is a blast and can kick some ***.
H/c/i + nitrous should be able to make close to 700 rwhp, but i need to worry about nitrous fills, and all the bs that goes along with it. Low maintainance otherwise and i think it would be a lot of fun. probably would cost 2-3 grand to do it how i want to.
Superchargers are obviously amazing because they make the power all the time but they are also expensive. Obviously its gonna cost me 6-7 grand to do this kind of stuff.
I am kind of talked out of a turbo charger due to the fact i feel they are a little less reliable, bleed off when you shift gears on the t56.
Old May 19, 2010 | 11:43 AM
30th t/a's Avatar
Stock ls1 heads on a 404? damn throw a set of good heads on it like TFS 235 & a FAST intake.
Old May 19, 2010 | 01:18 PM
pHEnomIC's Avatar
Well I am trying to figure out what I wanna do and do it right, no point in getting good n/a heads/intake if I wanna do a supercharger down the road
Old May 19, 2010 | 02:31 PM
JP's Avatar
JP
but you need a set of good heads/intake to even make good use of the 404
Old May 19, 2010 | 02:52 PM
jmm98LS1's Avatar
How was the shortblock built? Compression? Rings/gaps? Regardless of the power adder you pick, you need a better top end on that thing to take advantage of the displacement.
Old May 19, 2010 | 03:13 PM
LS1ROPER's Avatar
Get a good set of Heads(TFS) and Intake so you can enjoy that 404, you are leaving to much on the table as you are.
Old May 19, 2010 | 07:54 PM
pHEnomIC's Avatar
You guys arent seeing my point!
Why buy a set of crazy n/a heads that maximize compression and power and then have to switch to something completely different for a boosted application.
I realize this top end is far from optimal but i didnt have money at the time. I will have money eventually so i want to plan accordingly.
Old May 19, 2010 | 08:22 PM
06cobaltSS's Avatar
Id say go with the h/c/i over the supercharger. I added a supercharger to my vette and while the car is faster when i really lay into it, it is a lot lazier down low in part throttle situations. I can really feel the lost power from spinning the blower down low. When the car was na (450rwhp) it used to jump at the slightest touch of the throttle and felt a lot more crisp. Being you have a 404 you could make an easy 550rwhp and have a really strong fun car that would be hard to beat and when you hit the n20 all hell would break loose.
