Decent L92 setup
Old May 28, 2010 | 05:22 PM
JabaTheOnly's Avatar
Default Decent L92 setup
I have a 2002 Camaro SS. My car is in the shop right now awaiting a L92 with a 240/240 Cam, Full Exhaust with Headers. Tune and 4.10 gears. I was wondering what I should be looking at power wise?
Old May 28, 2010 | 05:27 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Why such a large cam with a single pattern?
Old May 28, 2010 | 05:44 PM
Honestly I left it up to the shop to choose a solid cam for me. I told them my car would be daily driven and I was looking for a viscous idle with some solid power accross the board. When I heard some of the specs on the cam it seemed as it was a bit big to be daily driven however I thought I would go ahead and trust them. As for single pattern I am somewhat lost because I lack knowledge in that area I am guessing. They told me the cam was a double pattern.
Old May 28, 2010 | 05:53 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Is this going into a stock L92 or are they aftermarket pistons with large valve reliefs?
Old May 28, 2010 | 05:58 PM
It is a stock L92 with springs and retainers. Its just too much isn't it ?
Old May 28, 2010 | 06:07 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Yes, that cam with a stock engine is too much. Did you have them check piston to valve clearance? I would turn the engine over by hand first to see what happens. Would hate to see anything be broken bent by not at least doing that.
I will not ask any names or anything, but you may hint to them to turn the engine over and also check clearances if they can.
What year model L92 is it do you know?
Old May 28, 2010 | 06:11 PM
Don't have the paperwork with me atm. Once I get off work I will try to find it. They are gonna drive it once they get done so if they blow anything they can feel free to hook me up with some extremely nice internals.
Old May 28, 2010 | 06:16 PM
I do know that it is coming out of a denali I believe an 07 or 08
 Michael S. Palmer
Old May 28, 2010 | 06:18 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Ok, I was just checking because now some of them have the DOD now. And that severely limits the lift you can go on them. That is why I ask.
Old May 28, 2010 | 06:26 PM
Oh Ok well I know its already in the motor from what I hear so I guess that I should just wait for their startup ?
Old May 28, 2010 | 06:27 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Correct yes. I hope it turns out well. From what we have seen, that is a little too much duration on a stock L92 for the intake side at least.
Old May 28, 2010 | 06:36 PM
Ok thanks for the information. What would you say the biggest size you would run and not be worried about issues?
Old May 28, 2010 | 06:45 PM
WKMCD's Avatar
No offense but the car is going to be a dog with that setup. Totally wrong cam. I wonder if the shop has done any L92 setups before. The cam in my 427 is smaller than that and the cam I had in my 403 L92 engine was MUCH smaller than that.
There, someone had to say it.
Old May 28, 2010 | 07:01 PM
Thank you for telling me this is what I needed to know.
Old May 28, 2010 | 07:03 PM
I am just wondering why this guy would say that texas speed told him this would be a perfect setup.
Old May 28, 2010 | 07:12 PM
Ok after hearing what all was said I called the shop and was incorrect about what cam he was going with in the first place. He said it is a 238/240 and that it is on the big side but runs extremely solid. Is this true or an incorrect statement from him .
Old May 28, 2010 | 09:07 PM
djsanchez2's Avatar
Cam specs still seem a little off for the square port heads. They like a bit of split between the intake and exhaust durations.
Some good examples being:
219/236
224/236
225/230
229/236
231/236
Old May 29, 2010 | 03:47 PM
87silverbullet's Avatar
Geoff@ Eps recommended for me to use his 230/246 cam in my stock cube l92 motor. You might want to check into getting a different cam before you put everything together to put the motor back in your car.
Old May 29, 2010 | 04:53 PM
mike c.'s Avatar
I agree with the others,that cam is not right. not even close!
Old May 29, 2010 | 11:17 PM
Ok well I will get back to everything I am gonna call him tomorrow and do some kind of change out and maybe even go to another shop. Thanks for the help and I will keep you up to date. Also does anyone know what a tuscani tiburon is my neighbor keeps saying I bet you the neighbors tuscani will destroy you. I hate imports especially tiburons lol
