what weight oil do you run?
http://forums.corvetteforum.com/c6-z...installed.html
the C6Z's oil system isn't that great and running on A6/R6's and have seat time it wouldn't surprise me if you're close to maxing out the factory "dry sump". As stated in that thread an aftermarket oil pan and baffle from ARE or the LPE/Aviaid combo would be a great starting point to ensure engine longevity. Oil wise, I'd honestly say go with a 15w-50 or 20w-50 especially if you don't have a better sump and baffle. Even with them I'd still run with the higher viscosity oil. IF price isn't much of a concern on the car for you, also look into the Joe Gibbs Racing Fluids. I've been seriously looking at the XP6 for my LS3 build in my Camaro (looking for ~520rwhp). My dad has a 66 vette with a solid roller 454 big block that he races and winds out to close to 8k, his engine builder has him using Joe Gibbs XP3 from the get go.
Here's more good threads for you to read on the C6Z:
http://forums.corvetteforum.com/c6-z...hard-data.html
http://forums.corvetteforum.com/c6-z...llation-2.html
http://forums.corvetteforum.com/c6-z...k-results.html
Oh, and honestly, Mobil 1 has some of the worst consumer line oils on the market. Their racing oil lines are still good, but also very expensive and hard to come by unless you go through them directly (also a minimum purchase quantity). For an over the counter oil, Castrol, Valvoline, and Redline are really what to go with. Redline has a good synthetic 15w-50 a lot of track goers use, and Valvoline has the VR1 20w-50 other track goers use (like myself).
You're engine builder may have his own opinion on this too. Wouldn't hurt to ask him as if something does happen to the motor at least he can't just say something retarded like: "Well you should have been running xxx brand and I could have warrantied it"
Ask him what he thinks about the Joe Gibbs XP6. JG oil is very unique. The XP3 which is a 10w-30, feels and looks very thin compared to your typical over the counter 10w-30. So I would imagine that the description of their XP6 would fit you very well, it's thin like a 10w-30, but provides the added protection of a 15w-50. Or maybe the XP1 would be better? I'm really no oil expert, and can only really give recommendations off my experience and others who go to the track often
I'd be interested to hear what your builder has to say though. I'm actually probably going to call JG's about my LS3 build and see what they recommend along with possibly changing oils in my racecar.I've always had the opinion that engine builders know oil better than anyone, as they all have their own preferences and they can give good information as to why
Often times the opposite is true . You need to talk with someone who is a chemist and involved in racing engines. Not saying they are all mislead, but many of them hate synthetic oil, recommend too high of a viscosity "because thicker oil is better oil" and the like. For example I am in contact with Dave over at Redline Oil in benicia california. He recommended their 5w-30 for my new 1200hp LS2 build. He agreed that a 50wt simply is not needed and way to thick for a stock clearanced LS motor. Keep in mind their 5w-30 acts as a conventional 10w-40 would in the bearings and cam. Polyol Ester synthetics have a natural viscosity index and need little to no viscosity improvers(this is where a conventional and high dollar Group V synthetic really differ, amoung other major differences). I have been using Redline for 16 years and love the product and support. They work closely with many top race teams. Many have redline under the hood and some big name conventional oil banner on the fender.
As dave stated, the increase of viscosity when moving to a 50wt is a bit much for a LS motor even with high hp due to all of their oils having high HTHS ratings and very high film strength. Even if some film stength was gained it would not be realized or needed for this application. Heavy oils are for large clearanced motors and air cooled applications. 50 wt in your street strip car is old school and not needed, but run what you want.
So, if when you start a road race that will last an hour and your clearances on the mains are .0020, what will they be in the middle and at the end of that race? Is it better to worry about the cold start damage of tight clearances and heavy oil or to worry about the late heat cycle loose clearances and a lighter weight? What is the lesser of the two evils?
I don't know if I'm trying to over-simplify this for my own understanding but I would love to hear some thoughts on this.
134k mile stock heads and stock bottom end running mid 10's on the bottle. I must be doing something right. I'll be gunning for high 9's this fall when it cools off.
Never heard anything on Pennzoil. Though I don't think that's a normal over the counter type Pennzoil, but I could be wrong. If it's there racing version (much like Mobil 1 makes an expensive high quantity only race oil), I'm sure it's probably good, but I have no idea.
There's a mod on here: Patman
He's the most oil knowledgeable person on this site; if you do a basic search on oil threads by him or with him you'll see what I mean. I PM'd him previously to chime in here, and heard nothing back and no posts..so I don't know how active he is here anymore (like most mods
