Need some help with compression
Old Jun 8, 2010 | 05:33 PM
SilverBullet73's Avatar
Default Need some help with compression
Hi everyone, I would like to know what compression I would get on a set of 243 heads milled 0.30 over or 62cc chambers with the stock shortblock and stock head gaskets? I did a search but I only get numbers for LS1's I want to have around 11.5:1 or so. I'm wondering if 62cc might be too much?
Old Jun 8, 2010 | 11:56 PM
hotswap's Avatar
On what engine? You'll need more info than that to calculate it. Bore, Stroke, Head gasket thickness, Piston dome volume, piston deck clearance?
Old Jun 9, 2010 | 01:29 AM
Pwebbz28's Avatar
My old ls1 with 59cc chambers and a .040 cometic was around 11.4-11.5 Thats with a -2cc piston
Old Jun 9, 2010 | 06:02 AM
davidws6's Avatar
Once you know your correct cc of the chamber, use this calc to find out .
http://www.angelfire.com/fl/procrastination/motor.html
Old Jun 9, 2010 | 08:59 AM
It's for a stock LS2 shortblock with the 243 heads milled .030 and the stock gm gasket. Thanks for the replies.
