Street 427 - ls7 block - cnc ls3 heads - all forged - cam advice needed
GUYS,
I am looking for a cam that will provide very high torque in a broad, flat band with a lot "under the curve" ... 6000-6500 RPM MAXIMUM ... Looking for long component life, reliability, MPG, and street-able POWER & STEALTH !
SPECIFICATIONS
(1) APPLICATION:
1995 Pontiac Trans Am (full weight), 4L85E A4 Transmission, Strange Engineering 12-Bolt rear end with 3.08 gears (3.42 - 3.73 ONLY if absolutely necessary), 25.66" diameter rear tires (315/35/17), Kooks 1 7/8" long-tube headers w/cats, Magnaflow Cat-Back exhaust system ... K-Member swap, etc, etc, etc.
*** Car MAY have to pass emissions, if I ever move to another state ... Visual only, for now, in NC for 1995 and earlier model years !
(2) ENGINE COMPONENTS:
BORE 4.125" X STROKE 4.000"
LS7 Engine Block, ARP studs throughout, CNC LS3 Heads (2.165" / 1.59" LS3 Valves), Callies "Dragonslayer" 4340 Forged Crank, Callies 4340 H-Beam Rods ( 6.125"), MAHLE pistons (11.1 CR w/ 70cc), Comp Cams Ultra-Pro Magnum Rockers (1.8 Ratio), F.A.S.T. 102mm Intake w/ 102 mm TB, 42lb.hr fuel injectors, etc, etc, etc.
(3) CYLINDER HEAD FLOW SPECS: (CFM)
.200 .300 .400 .500 .600 .650
INT 153 225 280 324 350 355
EXH 118 180 201 217 230 236
(4) CAMSHAFT:
I have been considering the following cams:
LINGENFELTER GT-11 215/231 @.050" .666"/.680" w/1.8 118 LSA
KATECH TORQUER LS3 224/236 @.050" .615"/.636" w/1.8 113 LSA
KATECH TORQUER LS7 220/244 @.050" .651"/.686" w/1.8 110+4 LSA
E.P.S. LS 214/232 214/232 @.050" .640"/.633" w/1.8 117 LSA
E.P.S. LS 222/242 222/242 @.050" .632"/.640" W/1.8 117 LSA
CUSTOM ???
I would especially like to hear from Patrick G. and other custom cam "guru's", but everyone is welcome to add their thoughts.
Remember these are CNC LS3/L92 heads, not LS7 or "aftermarket", per se . . .
Thanks,
Dave
SPECIFICATIONS
(1) APPLICATION:
(4) CAMSHAFT:
CUSTOM ???
Thanks,
Dave
LS1 Tech Administrator
A 7.0L is going to want 12-14 degrees more duration than a 6.0L would. Most 6.0L stealth cams are around 215-220 duration on the intake side with a small split to the exhaust to keep the overlap low. With this in mind, I'm wondering why you're looking at these cams with tiny intake durations and big exhaust durations? That's not really the stealth approach.
I'd recommend something around 230 on intake and between 230-238 on exhaust with a fairly wide LSA to keep the overlap low and the chop less dramatic.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Hi, Patrick.
My interest in those cams began with the GM High-Tech Performance Magazine article "Battle of the Bumpsticks" . . . They tested various "street cams" on a 6.2L LS3 crate motor. (Link Below)
http://gmhightechperformance.automot...son/index.html
I like the smooth idle characteristics ( less than 35-40 kPa MAP @ idle ) and ability to pass emissions, if necessary ( the LPE GT-11 has a -13 deg. overlap).
I am looking for a smooth, quiet, "near stock" idle with massive torque right off idle and having a broad, flat torque curve. Maximum RPM would be 6000 - 6500 and I don't want to have to run steep gears or a high-stall converter.
Basically, a "sleeper" that is definitely the wrong car to "try" at a stoplight, without "tipping my hand" to the other guy or every cop I end up next to in traffic.
The "EPS" cam lobes sound very interesting, but I don't know anything about them other than the little I have read online. Can you please tell me more ?
From what you said, it sounds like you are thinking 225-230 / 228-238 @ .050", right ? What about LSA (113-117) ?
Given the head flow data, I am thinking lift to be .600"-.650" w/ 1.8 ratio rockers . . . Does that sound right to you ?
What EPS lobes are available ?
Do you have any "ballpark numbers" for torque & hp, as well as RPM range for this combination ?
I am thinking between 550-600 ft./lb. max.torque . . . HP will depend on Torque at any given RPM, of course. Peak HP is not my goal, at all !
Many Thanks,
Dave
Patrick,
After looking at the EPS website and this cam and its specs, it looks like a custom cam is the only way to get what this motor truly needs .
http://www.engpwrsys.com/index.php?a...&productId=109
Does EPS have a list of cam lobes to choose from ?
I just want to be sure I get it right the first time, since camshafts are something of a "black art" to me .
Thanks,
Dave
Thanks,
Dave
The cam you need does not exist on anybody's shelf. It's going to be a custom cam for sure. The EPS lobes work very well with 1.8 rockers and the valvetrain components you spec'd. If you'd like me to spec you a custom cam, just click the cam help link in my signature and follow the instructions.
__________________
LS7. Ive seen a lot of dyno graphs on these and it is nice. Katech also runs these throrugh their spintron and picks proper valve springs (beehives in this case) for best valvetrain stability.
Some of you guys are thinking that the LS3 needs some kind of wild 15-20 degree split between intake and exhaust. This is not good thinking for this application. Remember, he's got a large motor, but limited rpm range. A smaller split to the exhaust will allow him to run more intake duration (which will help overall power) and run a smaller exhaust event which will keep overlap lower (improving street manners and stealth).
__________________
Hi,
Sorry to have dropped out of the thread. I pulled some muscles and partially tore the collateral ligament in my right knee, playing softball on Friday.
The heads are the SDPC (Scoggin-Dickey Performance Center) CNC LS3 / L92 heads.
http://sdparts.com/details/scoggin-d...-center/sd8800.
Dave
Dave
Patrick,
I am going to fill out the form and get you to spec out a cam for me, but I have a favor to ask.
If it wouldn't be too much trouble, please spec out both a 427 (4.125" x 4.000") and a 454 (4.200" x 4.000"), both with the same 6000-6500 max RPM, as there is a chance that I may be able to pick up an LSX block for half price !
All other components will be the same.
Thanks,
Dave
Thanks,
Dave
Pat spec'd a cam for my 408 with LS3 top and nailed the idle I was looking for! For sure you'll need to go custom cam. He spec'd it 9mos ago and slid it in couple weeks ago and love it. You'll pull more because of the extra cubes you have. For sure I'll be close to mid 500s n/a...once I get my good tune in...
