460 RHS block build at Nelson Racing Engines
So that block allows for lifter changes without head removal?
This will definitely be my N/A LS dream engine. It will be pretty sick for Bad Penny to tear up the autocross and road courses... Not that Penny isn't already pretty capable.
And thanks for the comments on Penny, she's coming along.
I was reading about the RHS block earlier, I believe it said that it could go all the way to 502ci. Rediculous
This build is AWESOME! I'm subscribing, can't wait to see some results. Also, did I miss it, or what vehicle is this monster going in?
Alot of the high RPM import guys are taking them out because the oil throws the motor off balance at high RPM. The Parts list looks good!
Here's the car it's going in:
http://www.youtube.com/watch?v=fZiMdUAM0sI
Here's a look inside.. what caught my attention was the provisions for oil squirters.
The sad news is that they won't be out in time for me to use... but it's nice to know they are on the way. There are four ports and each port will support two emmiters.
Opened up the Mast Motorsports "black lable" heads today and they are beautiful..
LS3 12 Degree 4.125 - 4.200 Large Bore CNC 6-Bolt
Solid Steel Race Valves 2.200 Intake
Solid Steel Race Valves 1.060 Exhaust
GM OEM LS7 Rocker Stands
Dual Premium Nitrided
Ti Dual Spring Retainer
Steel Dual Spring Locator
Machined Steel 7 Degree
The rockers are nice and light at least..
I hope we get midbuild pics, i wanna see all the cool moving stuff before it gets shtuck in the car.
i was actually gonna ask about that, but i figured you went with them for strength (i havent done much research into valvestrength, but i know the stock valves in the ls3 heads im using have hollow intake stems)
