6.2 in a 2000 silverado????? HELP
Fuel injectors, can i use mine from my 5.3??
Reluctor wheel is a 58tooth and my truck is a 24tooth??? what to do???
Knock sensors in valley cover??? Leave them unplugged and tie up harness??
Plan on using a std timing chain and cover(deleting the VVT) any issues??? Should i use my cahedral 5.3heads and intake or will it kill the Power it makes And if i need to use the L92heads and intake i am assuming i can use my throttle body on a L92 intake or L76 intake since my truck is cable driven??? Im not trying to build a drag truck, the idea is my truck is payed for and i would like the torque and HP of the L92, it will make things easier when i am hauling my car to the drag strip.... And i have a 24tooth LS1 crank sitting in the corner, could i use it in the block if i need to change or is their an easier way??? OK GUYS I NEED HELP!!!!!
My 09 Sierra Denali has the LS3 6.2L in it, and you will have plenty of power with it, Mine came with 405hp and i tow my car and trailer and cant tell it even back there
Like was stated above,
1. I doubt your stock injectors are big enough for your new engine
2. Lingenfelter's converter box, I have one, it works great, no issues
3. Mount knock sensors on side of the block, casper makes extentions, I'll attach a LS2 conversion with the mounting info in it
4. deleting VVT shouldn't be a problem, check with tuner though
5. Use L92 heads
6. SLP makes a wire adapter for the L76/L92 intake manifold
7. Using the converter box as stated above will be a lot easier, and less time consuming than swapping cranks.
http://www.ls2.com/forums/showthread.php?t=626014
Hope this helps
