what a good vacume reading
Old Aug 9, 2010 | 10:05 PM
35th camaro's Avatar
Default what a good vacume reading
402 with 236-242 cam 112 degree and ls6 intake, what vacume at idle should i see, i am getting 72 kpa(9in) at idle
Old Aug 10, 2010 | 12:20 AM
sssalah's Avatar
Looks slightly on the lower side, I've seen a couple of stock cubed around the same size cams with better 63-68 kpa. High compression and more idle advance should help.
Old Aug 10, 2010 | 05:33 AM
i have 10.6cr, like to hear from some guy's that has similiar cam, heads are patriot stage3 2.08 intake and 1.6 ext.
Old Aug 10, 2010 | 08:25 PM
ChucksZ06's Avatar
I have similar heads and comp. Cam is 248/256 on 110. My kpa is about the same between 70 and 75.
