ID'ing valve springs
Old Aug 13, 2010 | 08:11 PM
ponyracer's Avatar
Default ID'ing valve springs
I'm putting together a 6.0 iron block with l92 heads. The heads are nib from scoggin dickey and have been decked a little to bump the CR to 11 to 1. I'm trying to ID the springs, they have a med/dark blue stripe, single, beehive design. These sound alot like Comps 918's but did chevy ever make a design like this? I don't want to run the springs unless I can ID them, hate to destroy my new motor.
I can get pics if there needed. Also the engine came with a assa 550 lift cam and everything else was hi spec, arp etc.
Thanks!!
Old Aug 13, 2010 | 08:53 PM
Darkman's Avatar
May be the LS6 Spring.
https://ls1tech.com/forums/generatio...6-springs.html
Old Aug 14, 2010 | 12:10 PM
ponyracer's Avatar
Possible but the mounted height isn't correct. Mine are 1.82 to the top of the spring.
Old Aug 14, 2010 | 12:49 PM
alexplantman's Avatar
Originally Posted by Darkman
What he said!
Old Aug 14, 2010 | 01:36 PM
68 RS Convertible's Avatar
Thanks!!
If you got the L92's new then thats what the springs are, just stock L92 springs. I think they are good to about .570 lift or so. If you search around you should be able to find the lift rating. My L92's had the same springs when I bought them new.
Old Aug 14, 2010 | 02:38 PM
SweetS10V8's Avatar
None of the sets of L92 heads ive ever taken apart ever had springs that could take .570" lift. more like .500-.525" max
Old Aug 14, 2010 | 06:17 PM
sorry, I searched the stock L92 valve springs. GM p/n 12589774 and are rated to .510 valve lift. didn't mean to give any bad info.
Old Aug 15, 2010 | 01:04 PM
ponyracer's Avatar
I didn't buy them but they are new from scoogin dickey, the part number on the boxes = bare head castings?????
12615361 is the number off the box, they were assembled with springs and valves when I got them. That number doesn't cross to SD anymore but it does cross to other stores as a bare head. Not sure when these were bought, prob awhile back.
Here's some pics....
Old Aug 16, 2010 | 06:36 AM
SweetS10V8's Avatar
They look stock to me.. Get them in a spring checker....
Old Aug 16, 2010 | 07:23 PM
ponyracer's Avatar
Great, looks like I need to order some springs....
