Coolant blockoff rear of Heads
Old Dec 26, 2010 | 08:06 PM
LT1Formula007's Avatar
Originally Posted by edge04
that is from magnacharger but you can get them from NAPA
You wouldn't happen to have a part number would you???
-Thanks In Advance!
-James
Old Dec 26, 2010 | 09:57 PM
Snyper's Avatar
-Thanks In Advance!
-James
X2- this thing looks perfect for my setup.
Old Dec 26, 2010 | 10:53 PM
Vesper TA's Avatar
I used a crossover off an l92 truck for the rear, and an ls3 for the front. I tied them together with a hose from back to front using a brass tee, and into the radiator. It's been working great so far.
Old Dec 27, 2010 | 12:22 AM
jegten's Avatar
^^do you have a pic with them connected as you mentioned? thanks!
Old Dec 27, 2010 | 12:24 AM
Snyper's Avatar
So the rear cross over is the front cross over on an L92 truck? Part #?
Old Dec 27, 2010 | 02:46 AM
Vesper TA's Avatar
Not any good pics, but here are two. First you can see the line run over the intake, but not connected yet in the front. In second pic it's connected with the brass tee. Sorry not very good pics, but it's all I have at the moment. I can get better pics tomorrow if needed. The line can be run under or over the rail.
Old Dec 27, 2010 | 02:48 AM
Vesper TA's Avatar
Yes, the rear crossover is the front from an l92. I don't have a part number sorry. It came with a complete l92 I was rebuilding to use.
Old Dec 27, 2010 | 04:14 AM
Snyper's Avatar
What do the L92s come out of again?
Old Dec 27, 2010 | 10:06 AM
Gordon0652's Avatar
Originally Posted by bluehawk2
I am getting the water vapor collection block from kurt Urban. It ties all 4 into 1
I think in a high hp situation it is nessecary
http://www.kurturbanperformance.com/...or-system.html
It allow you to use an lines to connect to the dist block and then to the radiator.
Thats what i will be using.
Old Dec 27, 2010 | 12:09 PM
jegten's Avatar
thanks for the pictures!!
and the info on the l92.
it helps. just now to find out a vehicle where the l92 comes in to go to NAPA.
EDIT: btw, what intake is that you have?
Old Dec 27, 2010 | 12:10 PM
Vesper TA's Avatar
07+ Escalade, Denali, Yukon.
Old Dec 27, 2010 | 12:21 PM
  #32
Vesper TA's Avatar
It's an home ported l76 with an ls3 beauty cover.
Old Dec 27, 2010 | 02:03 PM
  #33
jegten's Avatar
thanks!
it looks nice.
what kind of hose did you use to connect the crossovers?
Old Dec 27, 2010 | 02:36 PM
  #34
Vesper TA's Avatar
thanks!
it looks nice.
I used a 1/4" fuel hose.
Old Dec 27, 2010 | 05:19 PM
  #35
litle88's Avatar
Nice!! Thanks I'll be using this as well!
Old Dec 28, 2010 | 02:10 AM
  #36
jegten's Avatar
i just realized i have another ls1 crossover. will have to check if it works in the back.
Old Dec 28, 2010 | 12:04 PM
  #37
oldngray's Avatar
I used a method similar to the Kurturban, I used the block-off plates and drilled and tapped to 1/8 pipe , a few straight fittings, a few "t"'s depending on how you wish to plumb it and you are finished with you own custom steam line !!!
Old Dec 28, 2010 | 03:45 PM
  #38
jegten's Avatar
did you have to bend it at all to make it fit in the back with the spout still on the right side?
they have an angle when they connect to the heads, so if i flip the front to the back, the spout ends up on the opposite side. hope this makes sense. thanks!
Old Dec 28, 2010 | 04:16 PM
  #39
Vesper TA's Avatar
The only bending I had to do was move the crossover pipe up just a tad to plug in the cam sensor. It can be done by hand once it's bolted to the heads. Other than this it bolted right up.
Old Dec 28, 2010 | 07:01 PM
  #40
jegten's Avatar
got it. on the l92 trucks, the crossover spout is on the left.
thanks.
