Coolant blockoff rear of Heads
Old Aug 18, 2010 | 03:38 PM
BKnBLK05's Avatar
Default Coolant blockoff rear of Heads
I just need a clear answer on the steamholes on the rear of a my heads,New Camaro Stroker build,The stock L92 heads were blocked off at the back from the factory,Now X headed, turbo, hi hp setup,Do I need to tie these into the front crossover tube or just block'em off like the factory heads were? Thanks in advance...Trying to get this thing done
Old Aug 18, 2010 | 03:52 PM
bluehawk2's Avatar
I am getting the water vapor collection block from kurt Urban. It ties all 4 into 1
I think in a high hp situation it is nessecary
Old Aug 18, 2010 | 08:59 PM
BKnBLK05's Avatar
Thanks bluehawk2..................anybody else? just wanta see if this is critical on the rear...
Old Aug 18, 2010 | 09:06 PM
nysbadmk8's Avatar
7 and 8 are the hottest, any way to move more coolant around them is a benefit.
Old Aug 19, 2010 | 03:19 PM
BKnBLK05's Avatar
Thanks fellows,I'll be making this mod,motors already in the car,guess I'll get another crossover tube from Chevrolet and tie'em together back to front..
Old Aug 24, 2010 | 06:53 PM
99LSS1's Avatar
This is what we did for my 402 build. Quite easy to do and hopefully it will keep the rear cylinders a bit cooler!!
Old Aug 24, 2010 | 09:02 PM
Big_Bird_WS6's Avatar
i thought of this. but then i just conected mine all together. and then back to the rad.
where does kurts leak out at?
Old Aug 24, 2010 | 10:03 PM
edge04's Avatar
how did you connect them front to back? any pics?
Old Aug 24, 2010 | 10:47 PM
bluehawk2's Avatar
http://www.kurturbanperformance.com/...or-system.html
It allow you to use an lines to connect to the dist block and then to the radiator.
Old Aug 25, 2010 | 07:42 AM
99LSS1's Avatar
Yea, We used 3/8's hose and some bent breke line. Hopeflly these Pic's are clear enough.
Attached Thumbnails Coolant blockoff rear of Heads-speed-secrets-ss-047.jpg   Coolant blockoff rear of Heads-speed-secrets-ss-041.jpg   Coolant blockoff rear of Heads-speed-secrets-ss-042.jpg
Old Aug 26, 2010 | 09:31 PM
edge04's Avatar
I didn't even check my TFS 235 but I would imagine the back ports are just blocked off??
Old Aug 26, 2010 | 09:40 PM
TransWS6Am's Avatar
i think im going to order one of these. seems like a very good idea.
Old Aug 26, 2010 | 10:09 PM
edge04's Avatar
also need to see if it will work with a maggie supercharger on top
Old Aug 26, 2010 | 11:44 PM
Irish350's Avatar
whats high hp?
Old Aug 27, 2010 | 08:47 AM
cam's Avatar
cam
I spent a lot of time researching this a while back and received some good info here so I hope it helps you out
https://ls1tech.com/forums/forced-induction/630983-will-ls6-coolant-tube-conversion-hurt-cooling-system-performance-2.html
Old Aug 27, 2010 | 10:14 AM
only reason i went a different route is where do i mount the little black thing on my ls2 intake. lol. and i bought these. and bought 2 t fittings and 2 elbow fittings and then got braided line and conected them. and looks stock.
Old Aug 27, 2010 | 10:47 AM
edge04's Avatar
Wll the Kurt system will not work with my SC intake so what I am thinking about doing is putting another crossover line like this one on the back my question is: can I just run a line from the front to the back and then "T" these into my coolant system such as into the lower radiator hose or heater hose? or is using the above Wegner fittings a better option?
Old Aug 27, 2010 | 12:11 PM
where did you find that? i would have used that if i had two of them. lol.
Old Aug 27, 2010 | 05:49 PM
edge04's Avatar
that is from magnacharger but you can get them from NAPA
Old Aug 29, 2010 | 11:04 AM
edge04's Avatar
I am going with two of these and then going to T them together and run a line to my lower radiator hose. Should work fine
