05 C6 LS2 Stock injectors
Hey Guys,
I'm going through a mandatory tear down of the top end of my motor due to a lifter failing and beating up my cam. I've decided to add a few ponies while im in there by adding a newly spec'd PatG cam geared toward NA and a fast 102mm intake ported by vengence.
My question is, I was putting down 426HP to the ground before and I hope to have added 40-60 HP with the add ons. How much horse can the stock injectors support? I'm not even sure what pound injectors they are.
Thanks for the help,
DOA
DOA
33.9 lb @ 4 bar
Your IDC'S will be too high in the 450 rwhp range. I suggest going to a 42lb injector.. for future growing room.
Could you get away with it? Yes.. Should you? up to you.
