oil pump o-ring
Old Aug 20, 2010 | 10:22 PM
dimetweaker's Avatar
Default oil pump o-ring
I have a L92 that I put a conventional cam in as well as forged rods & pistons. I am using the stock L92 oil pump, with a LS2 oil pan and pick-up ( 2005 corvette stuff ) I bought both the blue and the red o-ring, does anyone know which one I should use for a proper fit? THANKS!!
Old Aug 21, 2010 | 06:10 AM
69LT1Bird's Avatar
GM Oil Pick-Up Tube O-Ring (1st Design)
12557752
BLUE SEAL
Specifics:
* Oil Pick-Up Tube O-Ring ea.
* Chevy/GMC Pick-Up (1999-2000 LS V8) 1st design
* F-Body (1998-2002)
* Cadillac CTS-V (2004-2007)
* Corvette (1997-2008)
* Thickness = 3.55mm (0.140")
ID = 23.60mm (0.930")
Old Aug 21, 2010 | 09:23 AM
sparkwirez06's Avatar
if your using an ls2 pickup you need the o ring for that pickup.
Old Aug 21, 2010 | 11:51 AM
okay, the blue one came with the pick-up, i bought the red one just in case. thanks for the response.
