L76/LS7 Swap questions.
Old Aug 22, 2010 | 04:46 PM
Boi1da's Avatar
Default L76/LS7 Swap questions.
I have a G8 and was wondering how hard or easy it may be to swap my L76 for an LS7. I can get a pretty good deal on the LS7 so instead of adding a bunch of different pieces to get close to 500rwhp I figured I could start closer then add pieces. Is this possible and how much (if any) modifications will I need to do to make it work?
Old Aug 23, 2010 | 03:23 AM
rsz288's Avatar
If you wet sump the LS7 it is pretty straightforward and a reasonably common swap. There is even a factory LS7 tune as a special G8 model downunder came with the LS7 (not a factory fitted engine though). The stock dry sump pan doesnt fit in the G8 as is.
Old Aug 23, 2010 | 09:23 PM
Boi1da's Avatar
So it looks as if the only modifications would be to the oil pan or location of the oi pan?
Old Aug 23, 2010 | 11:18 PM
rsz288's Avatar
And somewhere to put the oil tank and related hardware.
