Please help diagnose this noise
Started with dino oil, 200mi, changed and added 10w40 Mobil 1, ran for ~500-600mi, changed to Pennsoil 10w30 synthetic at ~800mi and motor developed this knock around 200mi later. Oil pressure is around 45psi cold both before and after the knocking developed (no change).
Engine has been street tuned with wideband, afr is around 13:1 at high rpm with no knock detected (conservative tuning).
http://www.youtube.com/watch?v=g_J1q6oj5yM
This vid was taken about 20 min ago. I've taken the valve covers off and everything is tight (collapsed lifter not likely). As everyone knows I need to yank heads to find out if this is lifter related so I have a while to go before I get there. I'll update this thread once I know for sure what's wrong, however I'm hoping someone might know that noise right off the bat. I do have a magnetic drain plug so as soon as I drain the oil I'll have an idea of what might be wrong (needles from the lifter bearings, chunks of ____, etc).
I'm REALLY hoping for a lifter rather than crank/rod bearing. Sure I'll need a new cam or a regrind, but at least I don't need to yank the motor. I'm NOT happy about the possibility of having to yank that motor again.
Second lobe from the front of the block (#2 cylinder) is toast due to the lifter completely crapping out. Its flat on one side with big chunks completely blown out of it.
John, I'll be calling you guys tomorrow to help figure out the best plan of action going forward. I obviously need a new cam, I have new GM lifters but I'm not sure those are the way to go.
All the parts I have on this build are sourced from Texas Speed and they have been good to me so we'll see if we can get this one nailed for good!
Thanks to everyone for the suggestions!
