Hello to all..My question is this....What is the difference between the two? I know the LS2 is in the corvette, GTO, Trail Blazers, SSRs and the L76 is in the G8 and there is a variant made by Holden, but what is the difference between the engines? Any specs out there on the engine / cam / heads? A buddy of mine is going to look at an engine advertised as a "6.0 LS3 engine". When he called on it the guy told him it was a "L76 crate motor" from GM. I was not aware they made it (L76) as a crate motor. So either he did a mis-print or he does not know what he has?? From what I know an LS3 is the 6.2L and the LS2 is the 6.0L. So where does the L76 fit in? And, is it a good engine for a swap? Does it have the VVT (active fuel managment, different cam or?) Can that be deleted? ALSO...If GM did offer the L76 as a crate motor, as they do the LS2, LS3, etc., does anyone know what the GMPP part number is? Any information is appreciated...THANKS AGAIN!
