6 liter ?
Old Aug 30, 2010 | 07:00 AM
dmracing's Avatar
Default 6 liter ?
I have a ls2 with a spun bearing. Can I take everything out of the block and put it in a iron 6 liter block?
Old Sep 4, 2010 | 01:12 PM
Jimbo1367's Avatar
meaning............? Then you would have a iron 6.0L with a spun bearing.
Old Sep 4, 2010 | 02:11 PM
IWGF's Avatar
WAT? Why don't you just do a stroker out of what you've got...
Old Sep 4, 2010 | 02:28 PM
bozzhawg's Avatar
Originally Posted by jimbo1367
meaning............? Then you would have a iron 6.0l with a spun bearing.
lol ...........
Old Sep 4, 2010 | 08:41 PM
nodrok's Avatar
I believe the answer is yes. However i think your ls2 may have a 58 reluctor wheel and the iron is a 24. If you use the same heads everything should be the same. I dont know why you would do the switch unless you were going FI or on the spray. If you use the truck heads I believe they have larger cc heads.
