400+ cube guys, what plug you running.
Old Sep 2, 2010 | 01:27 AM
LIL SS's Avatar
Moderator
Default 400+ cube guys, what plug you running.
I am replacing the 347ci motor in the 63 pick up with a 418ci motor. It's got AFR heads, 11.2-1cr and 245/260 cam in it. Wondering where I should start on a plug as far as temp? 6? 7?
Old Sep 2, 2010 | 02:08 AM
02 BLK WS6's Avatar
I don't consider myself an expert by any means, but if it were my engine, I'd start with a 7.
Old Sep 2, 2010 | 02:37 AM
Pwebbz28's Avatar
I run a 9 in mine
Old Sep 2, 2010 | 03:45 AM
silverbeast's Avatar
i run tr6's in mine for N/A.
Old Sep 2, 2010 | 05:37 AM
slow trap's Avatar
i ran a tr6 and the autolite equivalent in mine n/a and went 1 range colder spraying a small shot. you will get quite a few different opinions on heat range so take my opinion with a grain of salt lol. i kept the colder plugs in (think they are ngk tr7 ie) and didn't foul so a 7 or equivalent range will probably last if tune is good.
Old Sep 2, 2010 | 08:28 AM
1CAMWNDR's Avatar
TR6 N/A 421" daily driver.
Old Sep 2, 2010 | 10:43 AM
TransWS6Am's Avatar
NGK TR6 416ci LS3 11.32:1 compression. I ran TR55's at first but they where way to hot and i kept getting misfires. Id start with TR6 with your compression
Old Sep 2, 2010 | 04:11 PM
LIL SS's Avatar
Moderator
Thanks guys.. Assuming everyone is running a projected tip??
Old Sep 2, 2010 | 04:49 PM
03supercobra's Avatar
Yep, TR6's here.
Old Sep 2, 2010 | 05:36 PM
nysbadmk8's Avatar
Tr6 on my 402. 8's when spraying
Old Sep 2, 2010 | 06:05 PM
burgers's Avatar
Tr6 n/a
Old Sep 2, 2010 | 07:41 PM
Irish350's Avatar
samesies. 402 here.
Old Sep 3, 2010 | 04:05 AM
Pwebbz28's Avatar
I ran the BR7EF(TR7) in my 450hp 347. A six just seems like it would be too hot at that power lvl. Im no expert though
Old Sep 3, 2010 | 06:35 PM
Irish350's Avatar
my 430 hp 347 had tr55s..
shrug
Old Sep 3, 2010 | 06:46 PM
LS6427's Avatar
TR55 or TR5
gapped .050
Old Sep 3, 2010 | 11:25 PM
GasTiresandOil's Avatar
BR7EF while N/A and 9's or 10's with the bottle turned on.
Old Sep 5, 2010 | 02:11 PM
Jimbo'sZO6's Avatar
TR 6's in mine. 416 ci. 11.8 SCR N/A, no juice or boost ever.
Jimbo
Old Sep 5, 2010 | 08:26 PM
thedak's Avatar
Tr6
416 - 11.7 scr - na
Old Sep 5, 2010 | 11:19 PM
LIL SS's Avatar
Moderator
So how many of you are reading your plugs? Where is the heat line on the plug?
Old Sep 6, 2010 | 12:02 AM
DrkPhx's Avatar
Good question. I've experimented with different plugs and gaps and settled on the TR6 usually gapped at .035-.042 and the heat line is very close to the middle. I was also thinking of trying the NGK R5724-8 Racing plug at the track to see how it likes it.
This is a good link how to read plugs at WOT.
http://www.empirenet.com/pkelley2/sparkplugreading.html
