Least Expensive 6 Lt. Head Gaskets?
Old Sep 6, 2010 | 12:27 PM
chopperloco's Avatar
Default Least Expensive 6 Lt. Head Gaskets?
Low buck Iron block build...
Thanks
Dom
Old Sep 6, 2010 | 12:34 PM
69LT1Bird's Avatar
Stock GM gaskets are the least expensive and quality part.
Old Sep 7, 2010 | 08:58 PM
Austin@HPE's Avatar
Order gaskets for ls3 6.2 they are cheaper than 6.0 gaskets and they are used for either. GM 12610046.
Old Sep 8, 2010 | 06:50 AM
SweetS10V8's Avatar
Originally Posted by Austin@HPE
GM 12610046.
Im running these. I think they were somewhere in the nighborhood of $29-35 ea.
Old Sep 8, 2010 | 10:20 AM
racer7088's Avatar
yep and they are also an awesome parts as well. Those are 5 layer.
Old Sep 8, 2010 | 05:27 PM
hirdlej's Avatar
What's the compressed thickness and bore size of the 6.2 gasket vs the 6.0l gasket?
Old Sep 8, 2010 | 05:39 PM
69LT1Bird's Avatar
This is right from GMPP
"Part# 12610046
LS3 / L92 Cylinder Head Gasket. Single unit, required two per engine. .051"" thick, 4.08"" max bore. Standard LS head bolt pattern."
