6.0 build help needed
this is going into a mud only heavy *** truck.
i have a stock 6.0 truck motor,low miles bottom end with 317 heads on it.
my plans so far are reuse stock bottom end w katech rod bolts and new bearings and oil pump.
my questions:
should i use the 317 heads or a set of 243s that i have off of a 5.3 and have them milled?i dont want compression over 10.5:1.
how much should i have milled off heads?
which head gaskets should i use?
does milling heads create any issues with pushrods(assuming id buy new),or intake mating up/sealing?
any suggestions on a camshaft??
i have a good z06 cam,any good with this setup???
thanks
Andy
You can use the z06 cam if you like but I wouldn't expect it to pick up a ton of power, they aren't that much larger then stock. If you want to pick up some decent power I would go with a small 220/220 or something similar. A cam like that will have lots of low end and midrange power, which is what I am guessing you are looking for.
as far as low c.r.? i was just trying to make a little more power and not
affect the reliability,so sounds like a little more is ok.
any ideas on how much to keep c.r. where i want?? .030,.040???
thanks for the pushrod and cam info.
yes i am wanting to keep the power on the low end as much as possible.
any other reccomendations are GREATLY appreciated.
what is the thickness of the stock gm 6.0 gaskets? thats what i was planning onusing?
with this setup,and head gasket,how much should i have milled from
the 243 heads to reach 11.0:1 cr?
thanks
ive found the stock head gasket thickness about .051
and figuring ill mill aproc .030 off the heads and still be safe..
so if its free,and ive got the motor apart.
will the z06 cam be worth installing???
i am trying to do this super low-buck,just to make a few events this fall,and am building a stroker thru the winter months,so any input is awesome..thanks!!
