New 418 is alive :)
Old Sep 18, 2010 | 09:51 PM
LIL SS's Avatar
Moderator
Default New 418 is alive :)
First the clip, then the run down: http://73-ls1.com/63truck/fire_up_exsmall.wmv
11.1-1cr
AFR 225 72cc heads with light weight intake valves
Custom 245/260 106/109 .644/.629
CTS-V lifters
Super Vic Intake
NX 2 stage plate
4150 to dominator adapter
Dominator TB
Edelbrock 1 3/4 stepped to 1 7/8 HVMC headers (These need to get swaped out)
Dual Electric cut outs
EWP
Under Drive Pulley
No Accessories
The little 347 that was in it before was dressed the same but ran a set of stock casting heads with a Trex, simliar compression. Went: 11.45 @ 118.6 NA with a 1.60 60'
Went time in sig on a 100 hit with a 1.677 60'
I'm hoping the new motor lays down similar ET to the old motor on the 100 hit..
Old Sep 19, 2010 | 07:05 AM
LS1MCSS's Avatar
Sounds sweet.
Old Sep 19, 2010 | 06:59 PM
fuel's Avatar
nice and choppy
Old Sep 19, 2010 | 08:20 PM
DrkPhx's Avatar
Thumbs up
Congrats on getting the new motor done. That is choppy, but sounds nice.
Old Sep 19, 2010 | 08:24 PM
PadenAlbin's Avatar
sounds so nice!
Old Sep 19, 2010 | 08:56 PM
JoeyD's Avatar
Sounds great. What kind of cutouts?
Old Sep 19, 2010 | 09:32 PM
sixt9er's Avatar
Naaaaaaasty idle! I luv it!
Old Sep 19, 2010 | 09:52 PM
Josh18Fan's Avatar
That sounds great. If it runs half as good as it sounds, you'll hit your goals for sure.
Old Sep 19, 2010 | 09:59 PM
LIL SS's Avatar
Moderator
Funny thing is the cut outs are closed except for the last 5 seconds of the video. That is through dual 2.5" turbo mufflers. The 347 Trex combo didn't even sound that ratty..
Old Sep 21, 2010 | 12:51 AM
sixt9er's Avatar
Are you from/in San Jose, CA?
Old Sep 21, 2010 | 01:58 AM
LIL SS's Avatar
Moderator
Live in the area.. A bit south of San Jose though..
Old Sep 21, 2010 | 05:03 AM
NXZ28's Avatar
Very similar to my 415 setup. Who tuned it for you? I couldn't download the video because I'm at work and of course it's blocked. I will have to download it tonight.
Old Sep 21, 2010 | 06:43 PM
LIL SS's Avatar
Moderator
I'm doing my own tuning.. Been doing my own tuning since 01.
Old Sep 22, 2010 | 01:35 AM
NXZ28's Avatar
I just watched the video this morning. Sounds freakin nasty. Did you notice any difference switching from the 4150 to 4500 throttle body?
Old Sep 22, 2010 | 12:35 PM
LIL SS's Avatar
Moderator
Never had a 4150 on it, it's always had a 4500. The little 347 wore the same external parts. I did switch from an LS6 to the current Super Vic / 4150 to 4500 adapter and Dominator TB. Here is a link to the dyno overlay: https://ls1tech.com/forums/dynamomet...7-results.html
Even though there was a slight loss in TQ from the Super Vic, the gears made up the difference. LS6 and 3.73's best 60' was a 1.67 (11.96@113). Super Vic and the 4.56's went 1.59 (11.45@118.6). That's with a 30" tall DR.
Old Sep 23, 2010 | 06:58 PM
dracamaro's Avatar
Im wqnting to run right round a 416. But on 11.5 or 12 to 1 compretion. Will i stay on pump gas or need race gas
Old Sep 24, 2010 | 03:56 PM
LIL SS's Avatar
Moderator
It's gonna depend on your valve events (Cam Shaft).. Most likely you will be ok with pump gas.
