quick fast 90 question...
Old Sep 23, 2010 | 07:20 PM
ToddAlmighty's Avatar
Default quick fast 90 question...
so i have an LS2 GTO and i just bought a fast 90 intake from a member, seems i need a different fuel rail correct? anyone got a link to a previous post concerning this? i searched my *** off and either suck or there isnt one. thanks guys.
Old Sep 23, 2010 | 07:40 PM
00 black ss's Avatar
im pretty sure you dont need another fuel rail. stock rails should fit without a problem. its if you get a fast 102 you need to switch rails
Old Sep 23, 2010 | 07:46 PM
SweetS10V8's Avatar
LS2 GTO requires a conversion kit for the OEM fuel rails to fit. Its part number #54026, I used to run it myself. Ill look and see if I still have it laying around in the garage.
Id look in the calssifieds too.
Old Sep 24, 2010 | 08:53 AM
JustAnotherLS2's Avatar
This.
Is it possible you can update us when you get it on. I would like to know about your gains, since I have basically the same mods as you.
Old Sep 24, 2010 | 07:19 PM
c6 batmobile's Avatar
You should be able to use the LS1 injector o-rings to get the rail to clear. Instead of the adapter kit from FAST you can use a washer to bridge the gap where the rail doesnt meet the intake. It will save you some cash and it will still work.
Old Sep 25, 2010 | 11:25 AM
SweetS10V8's Avatar
It doesnt work that way, the hole are in defferent postions. Its not a simple height change that can be filled with a spacer.
Old Sep 25, 2010 | 05:01 PM
I have the LS2 corvette. The motor and fuel rail is the same. I just installed my fast with LS1 injector o-rings and used washers to hold the rail down. I know the holes dont line up but with the right size washer it will overlap the tab on the fuel rail.
Old Sep 25, 2010 | 09:38 PM
SweetS10V8's Avatar
The 102mm FAST will work with washers, possibly, because it has an LS2 bolt pattern. THis is asking about the 90mm.
He needs to order the kit, I ran myself on the intake in my sig pic. You can see the silver LS2 OEM fuel rail and the 92mm FAST.
Old Sep 26, 2010 | 02:11 PM
I have a FAST 92. The bolt pattern is the same as a 90 because they were made for the LS1. Im telling you for 8 dollars in hard ware and the LS1 injector o-rings you can hold the fuel rail down and it will clear the manifold. If your picky about looks order the 80 dollar adapter kit.
