L92 milling fly cutting questions
Old Sep 26, 2010 | 04:47 AM
Gonzo98's Avatar
Default L92 milling fly cutting questions
Ok, Ive done some searching and still have some questions. I got some L92 heads off of Bruce@Powrmax, and I want to have them milled to bump the compression on my Lq9 to about 11.0 to 1. I figure that .030 will get me about there. Im probly gonna run a TSP 231/236 cam with this set up. Would I be safe going with a .080 fly cut for both intake and exhaust valves? I know that oh of the vavles needs more clearence righ? Any help would be awsome, I know and plane on checking the clearences just looking for something to get me going in the right direction.
Old Sep 26, 2010 | 08:07 AM
WKMCD's Avatar
What LSA? .080 is a lot. I'd start at .040 and measure.
Old Sep 26, 2010 | 11:21 AM
3pedals's Avatar
mock up the motor and check with a checking valve spring. I used an old fuel pump spring for my checker. then you'll know exactly how much to cut. that way you wont be going backwards by cutting too much, and reducing compression.
Old Sep 26, 2010 | 02:13 PM
c6 batmobile's Avatar
.080 is probably too much. That is close to the limit on a factory piston.
Old Sep 26, 2010 | 09:37 PM
hymey's Avatar
intake go .060" and leave it.
cheers
Old Sep 28, 2010 | 06:24 PM
Gonzo98's Avatar
Ok thanks for the advice guys, Ill let you know how it goes. Im getting the heads friday.
