Is this intake valve okay to use?? (pic inside)
Old Sep 29, 2010 | 06:06 PM
Mike_72's Avatar
Default Is this intake valve okay to use?? (pic inside)
I got an 05 GTO dropout and when I pulled the intake I found a bit of water in a couple of the intake ports. After pulling the heads I found a little bit of rust on the valve. I would like to get some opinions on if this is an issue or not. The engine will be bone stock internally.
Old Sep 29, 2010 | 07:07 PM
LS1MCSS's Avatar
Looks fine to me.
Old Sep 29, 2010 | 09:12 PM
KRAZY K 2000 TA's Avatar
looks fine
Old Sep 30, 2010 | 05:15 PM
Mike_72's Avatar
My main concern is the material that has been lost (however small it might be) from the corrosion that was on it before I cleaned it. Now you can see where the corrosion was and can see a small amount of pitting. Personally I would be very surprised is it has effected its strength, just wanted some expert opinions.
