anyone used the Morel "Street" Hydraulic Link-Bar Lifters
#62
I have asked him about lunati lifters vs ls7's, comps...etc and he recommended the lunati. However, he is a sales person so.....you know. And I'm a big fan of impartial opinions, and I hate when I call certain vendors on here and ask a simple question and I'm repeatadly tried to Be sold something...
That's why I'm asking here about reasons to use the more expensive lunati lifters over the tried and true ls7's.
#63
#65
Short travel lifters are very hard to work with if you don't have an adjustable rocker for sure. The main difference on the true Morel lifters to me are a more robust build quality as far as if abuse does happen. All lifters can turn fairly high rpm with good valvetrain but if you get some float or over revs etc. the Morel body and wheel and axles etc. can take a lot more beating if it happens for whatever reason.
#66
Good info, thanks for posting it. I'm right in range, measured 8-3/4 turns to zero lash on the Comp measuring tool and installed 7.250" pushrods.
#67
I've ran the street lifters in my motor with ls3 heads with 621 lift and now with some ls7 head and a 66+ lift cam and haven't had any issues to date. And the motor is shifted at 7000 all the time. the lifters do not like pre loading at all.
#71
