Lq9 Head/Cam upgrade help????
As you can probably tell i am new to the forum, and have been trying to read as many articles as i can. But i am new to upgrading the LS style engines, and i am LOST!! First of, a little about the truck, It is a 78 chevy, 6.0 vortec, turbo 350 tranny. that i am building to Play hard, and run a Hill-N-Hole Mud drag with. A Hill-n-hole race, is a 300' shallow mud pit, with 3 jumps in it that you can get pretty serious air off of.
What i have got is a 6.0 out of a about 2004 denalli truck, it is bone stock. I had a guy wire the factory harness to a stand alone, and he Deleted the EGR out, I am not running cats either. Just the 2 O2 sensors right after the manifolds. He also HP tunned it. and i am running a drive by cable throttle body.
So my question is, If this were your motor, and you had about a 3000$ budgett give or take a couple hundred. And you didnt care about drivability because it is never going to see the pavement, What would you do?
I am after Mid-High rpm power, This truck is going to be a drive on the Floor truck. So i dont care if i lose lower end. Because it has 6:17 gears in the axles, and i will run it in low range, which with this setup is a 2.73/1 ratio. I also have a cold fusion wet nitrous kit that i might put on it.. I think i have up to a 150hp shot nossle.
Another question is, (remember Im new to the fuel injection setups!) How much tuning, if any, will be involved after a head/cam swap? Because i wont be able to put this truck on a dyno and tune it like a car?
Heres some pics of the truck, it is almost done, just some odds and ends, and alot of painting!!
Pic of the cage before i started adding guessets, it now has guesset bars on all the main bars.
Any Help would be MUCH appriciated!!! Thanks!!
Hardest part will be the tune but its completely doable with a 3K budget if you buy used parts.
If not interested in boost then throw a cam/pushrods/valve springs and a tune at it. You wont need 3K to do that either
Talked to adam at livernoise about heads/cam... he suggested their stage 3 heads and 2R cam.. But i have read bad things about them on here.. what do yal think? I also explained to him how i wont be able to dyno tune it, and i ask if i mailed them my computer if they could get it "close" to where it should be. he said he could.. And he seemed very nice on the phone and asnwered all my questions.
