Thinking about stroker engine. HELP!!
Old Oct 27, 2010 | 11:47 PM
blackonblack02_Z's Avatar
Default Thinking about stroker engine. HELP!!
Well I am currently trying to finish up my truck with the 5.3 in it to get the suspension set up and get it working on the track. This summer I would like to have the new engine done for it and I am looking for some opinions.
I am wanting to build something around a 414 to 427 but am not sure of what seems to be the most effieceint bore and stroke combination on these. This is going to be a N/A motor with a vic jr and dominator style throttle body (4bbl) with worked 243's, at least a 2.02 if not a 2.05 intake valve (not sure how big or what works the best with these yet, still have more research to do) and a 1.6 exhaust. I am unsure of the cam yet because I have yet to determine the rest of my build. Honestly I will prolly just call cammotion and have one ground when its all said and done.
This is all going in a 01 GMC Sierra RCSB, with a TH400, 4200 converter, 4.56 gears and detroit tru trac. I am wanting to make a minimum of 600 RWHP with this set up N/A. I have been looking at the TSP aluminum 414 with the dome piston as I would like this thing to have a very minimum of 12:1. But as I mentioned before I am not sure if that is going to be the HP maker as far as Bore and stroke combos.
Any help or advise you guys can give me from personal experiances I would greatly appreciate. Just looking to make this truck move!!!
Old Oct 28, 2010 | 08:42 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Take a look at the shortblocks in my sig, I think one of our 415's, either iron or aluminum, would be just what you are looking to get. We have been seeing these engines putting down well over 600hp to the wheels with untouched LS3 heads!!!
GIve us a call if you are interested.
Old Oct 28, 2010 | 10:25 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I think we also have some good combos that will work for you! Give us a call also, we can put toghether a combo & port your ls6 heads for you.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Oct 28, 2010 | 12:28 PM
1lejohn's Avatar
Build the biggest engine that you can afford. Use an Iron block if you are giong to boost it, aluminum if staying NA. The down side to the alum. blocks are having to sleeve them for rebuilds. 600 rwhp is alot for a 414-416.
Old Oct 28, 2010 | 06:58 PM
TransWS6Am's Avatar
is this n/a? and this is to the rear wheels? that would have to be the most powerful n/a 415 with ls3 heads ever.
Old Oct 28, 2010 | 07:04 PM
What internals do you use in your short blocks?
Old Oct 29, 2010 | 06:19 AM
1lejohn's Avatar
I agree about the 600 rwhp for a 416 with LS3 heads. I haven't seen one yet.
Old Oct 29, 2010 | 07:52 AM
WKMCD's Avatar
Not going to happen without a carb/sheetmetal manifold. Probably not the hot setup for a heavy vehicle.
Old Oct 29, 2010 | 08:40 AM
LS1TECH Sponsor
Eagle Rods and crank, Mahle Pistons
Yes, it is to the wheels, it is in a car with a 3 speed jericho trans and a quick change rear end running methanol. It made 595rwhp on 110 sunoco.
I will try to get a dyno graph up today.
Old Oct 29, 2010 | 08:44 AM
LS1TECH Sponsor
Default Dyno Graph for the haters!!!
Red line is on Methanol, blue line is on 110 Sunoco.
415 with decked LS3 Heads - untouched ports
Truck intake manifold - untouched
90mm Throttle Body
Schwanke Road Race Cam
ASA Underdrive with full dry sump setup
Attached Thumbnails Thinking about stroker engine. HELP!!-415-ls3rr-chassis-dyno-runs.jpg
Old Oct 29, 2010 | 08:51 AM
LS1TECH Sponsor
Default SAE Corrected Graph
Just thought I would put this up there too, incase someone didn't like the STD correction
http://www.youtube.com/user/james02m.../0/jTF0j9TwNSI
Attached Thumbnails Thinking about stroker engine. HELP!!-415-ls3rr-chassis-dyno-runs-sae-correction.jpg
Old Oct 29, 2010 | 10:12 AM
Callies Performance's Avatar
If 600 n/a is your target, the Compstar LSc rotator is the ticket, and will save you some cash!
http://www.callies.com/compstar/speed-packs/
