Has anyone used the APEX or VICTOR REINZ full gasket kit that is on Fleabay?
I need to get a complete gasket kit for my LQ4 rebuild and I found this APEX kit on Fleabay, has anyone used it, or know anything about it?
http://cgi.ebay.com/ebaymotors/Chevr...Q5fAccessories
APEX FULL GASKET SET
A new application listing from a leader in gasket technology! This listing is for a FULL gasket set for 1998 Chevrolet Camaro & Pontiac Firebird with 346 LS1 LS2 5.7L engines. And 5.7L 346ci LS Corvette 1997-1998.
P/N AHS3072+ACS3071.
The following gaskets are generally included in full sets:
2 head gaskets
2 valve covers
2 intake gasket set
2 exhaust gasket set
1 oil pan set
water pump gaskets
water outlet gaskets
distributor gasket if applicable
fuel rail o rings if applicable
premium valve seals
rear main seal
timing cover seal and gaskets
and other misc gaskets to rebuild engine
DM
2 head gaskets
2 valve covers
2 intake gasket set
1 oil pan set
water pump gaskets
premium valve seals
rear main seal
DM
VICTOR REINZ FULL GASKET SET
http://cgi.ebay.com/ebaymotors/1999-...Q5fAccessories
Part #HS 5975/CS5975 (VICTOR REINZ FULL GASKET SET )
Chevrolet 346 (5.7) LS1 V8 1999-2001
(1998-2000) Camaro, Firebird and Corvette
(2001) Camaro and Firebird only
The following gaskets are included:
NOTE: The lower oil pan set is not included for the 2001 corvette.
2 head gaskets (Multi Layer Steel)
2 valve covers
8 intake gaskets
1 EGR gasket
2 exhaust gaskets
16 valve seals
1 rear main seal
1 oil cooler
1 oil filter
1 oil pan
2 oil pump inlets
1 timing cover
1 timing cover seal
5 water pump gaskets
and several other misc. gaskets
DM
2 valve covers
8 intake gaskets
1 EGR gasket
2 exhaust gaskets
16 valve seals
1 rear main seal
1 oil cooler
1 oil filter
1 oil pan
2 oil pump inlets
1 timing cover
1 timing cover seal
DM
