Alot of motor questions.
I am looking for it to do the fallowing things:
Rev to about 7500rpm all day long
Make 500 whp
Make 500 TQ
Make torque early in the powerband and last threw the powerband
Have a very responsive throttle
Be somewhat cost effective >6k total for motor and other main motor parts
Be very very realible- mostly worried about spinning a bearing
Everyone says oh thats easy but its the little things I can't seem to figure out. Like:
Is the fast manifold worth the 1000 or should I just get a ls6 manifold?
How much hp is the ls6 intake manifold good for?
what size injectors are needed?
How much of a difference does the throttle body size make?
How high compression can I go with 100octane?e85?
Are ls2 heads good enough for what I need? bore them out?
Whats the best way to control such a setup? stock ecm reprogrammed?
So far my shopping list is:
ls2 block with stock heads- I am getting this for a good price in good shape.
Callies comp star crank
Callies comp star rods
wiseco pistons
ls6 ported oil pump
I am also trying to figure out if I should get a good t-56, a 4 speed t-101 or g force trans if anyone has experience with either 4 speed transmissions please chime in.
Thank you gentlemen for answering any questions you can.
You also need to make sure your oiling system is good and maybe run something like an accusump to cover for you if you run the oil out from under the pickup ever. We have done several drift engines but the guys actually doing it are who need to tell you what to do. depends on the car as to what pan you will use but some are not that great for drifting and you will have to run an accusump.
Im keeping my RPM built t56 and ls7 clutch/ls2 flywheel
I think after labor for the swap and ALL of the little miscellaneous parts I decided to get (new 1-7/8 headers, k member) Ill be looking at like 8-9k, and thats before factoring in the old sold parts (my old AFR/fast setup paid for half of the gem I got from Erik)
anyone else?
I have a forged 404, ported l92s, 240/250ish cam, and fast 102/102 intake. I think my build would be pretty close to what you'd want. Like others said, victor jr if you really wanna make power to 7500, but the fast 102 would probably dominate in lower end torque and up to 6600-7000 it would start to cross over to victors territory.
To be honest, copy something like my setup, it should be pretty dang good for what you want.
