Quick LSA question
Old Nov 6, 2010 | 02:31 PM
JustAnotherLS2's Avatar
Default Quick LSA question
I see some guys here that have cams with LSAs, for example 112*. And see some with, for example 111+1. Whats the difference between the two? I know what LSA is and what it affects. I just want to know the difference between the two.
Old Nov 6, 2010 | 03:53 PM
SweetS10V8's Avatar
If you know what LSA is and what it affects, going from 111 to 112 is simply a 1 degree wider LSA between your intake lobe and your exhaust lobe centerline.
Do you not understand what the +1 is? Do you know what the intake centerline is? (ICL)
Old Nov 6, 2010 | 03:55 PM
Tainted's Avatar
the + is what advance is ground into the cam.
right? I think so...
Old Nov 6, 2010 | 05:40 PM
SweetS10V8's Avatar
It is... If the cam is 113+3 it means the ICL is 110, the ECL is 116, and the LSA is 113
Old Nov 6, 2010 | 05:41 PM
litle88's Avatar
holy **** TAINTED its been a while!
But yes you are correct sir
Old Nov 8, 2010 | 09:16 AM
Thanks Sweet.
