Ls9 heads
Old Nov 7, 2010 | 06:08 PM
red 454's Avatar
Default Ls9 heads
GUYS
what is the differance beetween a ls9 head and a ls3 head ? streangth/ 6 bolt / port shape valve size
comp ratio ect
i thought they were the same but i see that a lot of the big shops are building LSX engines with ls9 heads in stead of the ls3 or ls7 heads ??
Old Nov 8, 2010 | 02:21 AM
rsz288's Avatar
Originally Posted by red 454
GUYS
comp ratio ect
IIRC slight revision to swirl pattern with a fin in the intake port plus use 13mm bolts. And they are rotocast and potentially less porous due to the rotocasting method. Still 4 bolts per cylinder, 10 major bolts total.
Old Nov 8, 2010 | 09:22 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Correct, except they are 12mm bolts vs. standard LS 11mm. Also LS9 block and heads are made from the same 356-T6 material as the C5-R block.
Old Nov 8, 2010 | 09:58 AM
LS3RX7's Avatar
Do they have thicker decks any std GM heads?
Old Nov 8, 2010 | 11:25 AM
Roar's Avatar
I believe they have thicker decks and some more material between the valves.
Also, they come with Titanium intake valve and Stainless exheust valves.
Port design and flow should equal the LS3's as far as I have been able to find out (except for the swirl wing).
Old Nov 8, 2010 | 07:02 PM
rsz288's Avatar
......Doh! Got it.
Old Nov 8, 2010 | 10:30 PM
adam205348's Avatar
look into the LSX-LS9 and LSX-LS3 heads. Newer GM 6-bolt heads based on those designs.
Old Nov 12, 2010 | 07:50 PM
red 454's Avatar
thanks guys
looking for some thing with ls3/9 ports to suite my harrop blower manifold and 2300 but will suite a bit more boost then i have now (10 psi on stock internals ls3 )and hold the sleeves in place better
Old Nov 14, 2010 | 10:43 PM
t/a98's Avatar
I don't think your sleeves are going anywhere haha.. Your head might wanna lift but sleeves, naa.
Old Nov 14, 2010 | 10:47 PM
red 454's Avatar
been a couple moved here on 20 psi with ls3 heads
Old Nov 26, 2011 | 07:15 AM
QTB's Avatar
QTB
Sorry I'm kinda a noob when it comes to heads. But does this mean the stem will be longer on the valves for the ls9 heads vs the ls3?
I guess the more obvious question would be if the Ti valves will fit ls3/l92 heads?
Old Jul 22, 2015 | 04:50 AM
Camaros-n-Chevelles's Avatar
The part number for the LSX-LS9 cylinder head is 19213963.
http://www.jegs.com/i/Chevrolet+Perf...13963/10002/-1
The part number for the LSX-LS3 cylinder head is 19201805.
http://www.jegs.com/i/Chevrolet-Perf...ductId=1297514
