Comp LSR rectangle cams, opinions?
As with many, with all the voices and choices its hard to finalize the combo. How do they measure up again the popular XE-R Lobes?
I was looking at these three cams for my car:
Comp LSr Rectangle Cams
269LRR HR13 ADV 269/285* @.050"219/235* .607 .621 113° 1500-6700RPM
277LRR HR13 ADV 277/293* @.050"227/243* .614 .624 113° 1900-7000RPM
281LRR HR13 ADV 281/297* @.050"231/247* .617 .624 113° 2000-7000RPM
This is all for a 2006 GTO 6.0 M6. Cam will go in along with TEA stg1 CNCed LS3 heads, LS3 manifold/LS3 injectors, 1 7/8" LT headers, CAI inc intake, 160* thermostate yada yada....
Thanks guys, I appreciate your opinions
281/285* @.050" 231/235* .617 .624 114+2
Ask for lobe# 13018 and 13019 on a 114+2
One of my buddys has the 277Lrr, it made 470ish hp with 430ish torque starting at 4000 to 7000, it had some low speed drivabilty issues as well as in six gear.
My other buddy has the 281Lrr it makes about the same power but has bad drivabilty at low speeds, "I beleave he said under 2000rpm" however its not tuned correctly, I beleave drivabilty and perfromance could improve, it really shines at the track, we were at the track last week and it ran a best of 12.27
It really all depends on how your going to use the car, if you want great torque in the rpm range that you spend most of you time in "on the street" you won't regreat the 269Lrr
If your going to spend a lot of time at the track and in the higher rpm range the other two will work great.
Good luck, hope this helps it was the toughest choice I had to make.
Regards Htown
Over 500ftlb from start of pull through to redline with a peak over 600ftlb
BHP doesnt drop off it pulls right to redline (6500).. well a very slight decline.
That was running 0.60bsfc (ie) Ultra Rich, so I think there is another 5% in there with a decent tune.
Oh thats also with WCCH CNC LS7 heads..
Just my $.02
Christian
http://www.hotrod.com/techarticles/e...est/index.html
Lobes also seem happy with EPS, LSL, and not so much XER but the odd one here and there
All I can say for certain is am I ever pleased that I ordered a PatG custom grind EPS cam. Its installed now... numbers coming soon
I'd bet on the second cam, that you could cut the exhaust duration to 235* and only loose a few HP, most of it being above 6500, while gaining better low end drivability.
One thing that intrigued me is the flat torque tables that all the cams Hot Rod did versus all the high rpm spiking tables that gmhtp did?
http://hotrod.automotive.com/115281/...est/index.html
