Valve springs for boosted LSX ?
If I stay with the current lift, I think I may need to go to the 2.0 installed height as shown for the 1530s (current setup measures 1.8") - A bunch of my valve seals were totally destroyed. The increased open pressure may also help with that.
Wouldn't say my valvetrain is lightweight. PAC says that the small diameter of the 1530s is for lightweight valve trains - how does this relate to spring diameter? What retainers and seats do these use? catalog shows N/A
Any advantages re duals/singles?
We have an entire package with the 1521 or you can step up to the Manley spring.
Either the 221435 or the 221436 would work for you. On those heads though, you should be able to run a larger spring. There are so many available that are over 1.3 OD.
Let me know and I can get you set up with a kit that will not leave you worrying. Both of those springs I quoted are close to what you had as far as pressures. The 221435 has some more seat and open pressure as well.
As far as the 1521 is concerend i am affraid it won't be enough spring for 20lbs of boost. They would work on the exhaust side but intake i would suggest more.
I would not be affraid of putting 200lbs on the seat at all with that setup.
What ratio are those rockers?
I am shocked that only 160lbs on the seat is controlling 20lbs. of boost.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
http://www.summitracing.com/parts/KMO-K-800/
So bumping up the spring pressures to say 200/500 is the consensus? Better control without too much sacrifice in durability?
Either that or use +.050" locks, +.050 retainer etc.
REV has something against moving the lock groove on the valve.
Shane
keep in mind we can HS any spring to lower loads for a nominal fee. The spring rate will never change though.
