Valve springs for boosted LSX ?
Old Nov 15, 2010 | 05:09 PM
AES Racing's Avatar
Originally Posted by TurboBuick6
There ya go a 1.900 setup with the 1530's will put you right at 211lbs. with a .640 lift will put you about 570lbs on the nose.
keep in mind we can HS any spring to lower loads for a nominal fee. The spring rate will never change though.
What do you think of 570lbs open pressure with a hydraulic lifter?
To me sounds bit much for hyd. roller, 250lbs seat/600lbs open pressure i've seen 8mm rocker bolts get torn out of the heads with solid roller. My point is, if 600lbs of pressure is enough to take out a rocker arm, on the lifter/cam its taking a beating.
I
As far as the 1521 is concerend i am affraid it won't be enough spring for 20lbs of boost. They would work on the exhaust side but intake i would suggest more.
Backpressure doesn't concern you?
Old Nov 15, 2010 | 06:20 PM
XtraCajunSS's Avatar
The only hydraulic lifters I know of that are capable of withstanding that much pressure are a certain Morel (not all will handle it) and a Comp R or Shubeck style lifter. I personally think that spring may be a little overkill for your app. I wouldn't go over 200 seat and 500 open.
Just my $.02
Shane
Old Nov 15, 2010 | 06:40 PM
DrX's Avatar
DrX
Lifters are Morels, but I don't have a part #.
Old Nov 15, 2010 | 07:48 PM
TurboBuick6's Avatar
DEpending on his parts you are right. His set up looks pretty stout but pictures dont tell the whole story.
If you feel like waiting a few months we are comming out with some new ls1 duals that will be some killer springs. That is if you can wait. I know how the mod bug is, sometimes it doesn't like to wait .
As far as back pressure thats kinda touchy and I am not an expert there. You will have back presure but the same time there is blow through/scavageing going on. Even with the backpressure (now I may be wrong so don't quote me) you still have positive and negative pulsations.
Old Nov 16, 2010 | 07:07 PM
In your case, the Manley 221435's would be your best option since you are not sure on the Morels. I know the Morels are good at 500...
Shane
Old Nov 16, 2010 | 07:54 PM
WKMCD's Avatar
Good info guys!
Old Nov 17, 2010 | 11:47 AM
DrX's Avatar
DrX
Thanks for all the input. Any theories on how the the seals got hammered like this. Looks like they got hit from both sides.
Edit: Looks like Photobucket is out of order right now so the pics aren't showing.
Old Nov 17, 2010 | 01:00 PM
If your cup / I.D. locator was not the right size it would definitely let those springs walk around and beat em to death.
Too little spring pressure could do the same thing, though I would venture it was cup/ID.
Old Nov 17, 2010 | 02:02 PM
DrX's Avatar
DrX
It did take a fairly good tug to pull the inner springs off the locators.
The seal in the pic is one of the good ones. It's just scratched from me pulling it off.
Old Nov 17, 2010 | 02:05 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Seeing that makes me think of a vortec truck trying to run too much lift on stock guides. Looks like they were just pounded out. Maybe the seal did not hold well to the guide and it came up, got hit and hammered down, then the valve brought it back up again and repeated the process over and over. Did you check the height of your guides?
Old Nov 17, 2010 | 02:26 PM
Are both your intake and exhaust seals getting torn up?
Old Nov 17, 2010 | 03:39 PM
  #32
DrX's Avatar
DrX
I believe that 4 intakes and 1 exhaust seal were totally destroyed. Clearance does look a little tight for the lift I am measuring. Say .020" on this one. Just not sure how that would cause the bottom end of the seal to get hammered.
Old Nov 17, 2010 | 03:44 PM
  #33
Beau@SDPC's Avatar
LS1Tech Sponsor
Maybe its the lifters pumping up and smashing the seals and just hammering them down until they look like that. Did you check the height of your valve guides? You may be fine on coil bind and such on the spring, but just like with the old cast iron vortec heads, your retainer may be hitting the seal dead on.
It looks exactly like that is what was happening. So that makes me wonder if the valve guides have either backed out or were not installed in deep enough to begin with. Or the valve height/spring pocket is not consistent. Are the valve seats all in good condition?
Old Nov 17, 2010 | 04:06 PM
  #34
What is the .020"? Im sorry just not following what your describing. Yeah so sometimes i am slow lol
Old Nov 17, 2010 | 04:55 PM
  #35
DrX's Avatar
DrX
.020" is the distance from the retainer to the top of the seal(.660" valve closed) minus the max lift.
Old Nov 17, 2010 | 05:10 PM
  #36
DrX's Avatar
DrX
Valve seats:
Old Nov 17, 2010 | 05:12 PM
  #37
Brian Tooley Racing's Avatar
In spintron testing we saw upwards of .100" valve loft...and that was with valves that are much lighter than those.
The bottom of that retainer looks long too...maybe the ones TEA has would be shorter?
Old Nov 17, 2010 | 11:36 PM
  #38
Guys, its really no mystery here. I've seen this time and time again with any of Cary's heads. With the added weight of the valve (longer AND larger dia.) It is almost impossible to control a solid stem stainless valve ESPECIALLY with heavy shaft mount rockers AND 1.8 ratio. I promise, I've fought this battle more than once since the early ETP days. You will need the Manley 221435's set up around 190-200 on the seat. PROBLEM SOLVED. I have seen this issue on more than one occasion. As Brian stated, he is not only bouncing the valves off the seat but lofting them as well. That is what is tearing up his seals. I have many ETP LS6 and LS7 style heads in applications from mild to wild. Cary, Craig and I have been through the ringer on this stuff. I promise, buy the parts from whoever you want, I'm just trying to solve your problem for you.
Your only other option is TI valves... This would give you some insurance. Even the Manley's will be tasked at 20PSI with solid stainless valves...
Thanks,
Shane
Old Nov 18, 2010 | 09:21 AM
  #39
KsMySS's Avatar
I know this discussion is being centered around ETP heads. But do heads with a more stock geometry (AFR's, Trickflows, PRC etc..) have these same valve spring requirements?
Old Nov 18, 2010 | 07:34 PM
  #40
Anyone with boost that had problems with the standard TFS "max pressure" springs (160lbs seat/450lbs open) we would sell them the K-800 springs (200lbs seat/500lbs open)
This is generally someone who is running something like an XE-R or LSK lobe and boost, which is a bad idea.
If running boost, get a slower cam lobe, like the Comp Extreme Marine or something slow and stable. When running a hyd roller cam with boost, high RPM stability will buy you more top end horsepower than all of the ramp speed in the world...
