4.060x4.125
Old Nov 16, 2010 | 12:32 PM
Bobsmyuncle's Avatar
Default 4.060x4.125
can you swing a 4.125" crank in a lq4/lq9?
what does it require??
i've searched
Old Nov 16, 2010 | 04:59 PM
anyone....
Old Nov 16, 2010 | 08:57 PM
S10xGN's Avatar
I'd be worried about pulling the piston too far out of the bottom of the bore at BDC. Stick with a 4.00" stroke...
Old Nov 16, 2010 | 09:17 PM
Pwebbz28's Avatar
You CAN do it but like stated above it draws the piston quite aways out of the bore. The iron block has the shortest bores if I remember correctly. I agree with sticking with a 4.00 stroke.
Old Nov 16, 2010 | 10:10 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Ive had two 4.1" stroke cranks in an LQ4 block and niether lasted very long. The sleeves of the aluminum blocks are substantially longer and will help tremendously with piston rock at BDC.
