Mast Small Bore Rectangle Port Heads
Ok, so I'm confused. You say this motor has to have "stock style" heads. The you say its an LS9. And Ls9 is a 6.2L. The only motor with 6.0 are L76/L92 which are the 6.0L truck motors and a few Ls series cars (like some of the Holdens as an example). The Mast heads are an aftermarket casting. So, if you have a class that requires Stock casting numbers those heads won't make it.
So, what are the restrictions on what you are looking for, and is it really a 6.0L or a 6.2L?
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
P/N 510-302
Retail: $1499.99 ea
Flow Data w/4.000" Bore Plate
Lift Intake Exhaust
0.100 74 61
0.200 146 119
0.300 222 188
0.400 282 219
0.500 330 236
0.600 360 251
0.700 372 260
I have owned or seen all these heads on the dyno and the Mast/old ETP heads made the most HP and are superior quality.
Btw, i have been keeping up with ur car and alls i can say is its a bad bitch! Keep up the good work!
