Mast Small Bore Rectangle Port Heads
Old Nov 18, 2010 | 08:17 AM
Jenson's Avatar
Default Mast Small Bore Rectangle Port Heads
I only found one dyno for these heads, which happened to be on an LS1 short block, and Im curious if anyone here has any first hand experience. We are wanting to build a 4" bore, high compression (14.5-15.0) LS2/L76 short block using these heads. I also only found one dyno with them on an LS3 block...seems real world info is scarce on them for some reason. Or Im just looking in the wrong places.
Old Nov 21, 2010 | 09:39 AM
Jimbo1367's Avatar
I'd try TEA or AI L92/LS3 CNC'd. Better bang for the buck IMHO
Old Nov 21, 2010 | 10:42 AM
bozzhawg's Avatar
Its going to be tough, due to their cost..... They may have priced themselves out the market.... Especially with this economy, dropping that much bread on a head when there are other budget minded heads available....
Once they collect dust on the shelves for a while, we'll see sales if the egos does not get in the way. I don't know anyone with them, and I bet they prob are a great head, but the cost...
Bozz
Old Nov 24, 2010 | 04:24 PM
n20kid's Avatar
The price on these heads are not unreasonable.. The reason u don't find much on these heads on here is because these heads are more for the hardcore racing and havent been out long, especially here on tech.. Check on yellow bullett you will see alot of these heads on there.. U have to compare apples to apples, the only head that compares to these are the All Pro and they arent cheap either... Once u get one in ur hand u will see why they are the price they are.. Top Notch!
Old Nov 24, 2010 | 05:16 PM
Fbodyjunkie06's Avatar
I think either super chevy or hot rod maybe car craft did a several page article with a LS3 stroker with a bunch of different as cast and CNC heads and the Mast were one of them. Of course the Mast, AFR, and TFS all had the highest HP and TQ. TEA, TSP, Edelbrock and other's were also in the comparison.
Old Nov 24, 2010 | 06:38 PM
Kx69's Avatar
What makes them more for hardcore racing other than a hardcore price? I see AFR, TFS, and Allpro mentioned on YB more than Mast.
Old Nov 25, 2010 | 01:43 AM
ringram's Avatar
Why use the smallbore heads on a 4" bore!? Surely you want the std 4" bore ones...
Old Nov 25, 2010 | 11:01 AM
Jimbo1367's Avatar
That was the Dec/2010 Hot Rod It was a 408 stroker. According to the article, used a FAST LSXR intake and matching 102TB for the cathedral port heads . I would imagine they used the FAST 102/102TB on the MAST heads.
Old Nov 25, 2010 | 11:19 AM
taman86's Avatar
the article the op is refering to is in the GMHTP mag some time last year. they used a camp cam speced for these heads, fairly odd compared to standard ls cams. i think it was like 22x/24x cant really remember exactly. the numbers they picked up were not impressive at all. they put down only about 440 rwhp with an ls3 intake. plus the price for a set of BARE heads is 2500 bucks, then with the options of rocker arms, pushrods, valves, and springs, and all those are nothing special to them just standard GM comes out to about 3200 bucks if i remember when i happened to price them. with a good set of standard ls heads such AFR, TFS, TEA, or nice set of ported 243/799 and a good cam you achieve those numbers and exceede it for about oh, 2 grand less. so what is hardcore for who?
Old Nov 25, 2010 | 11:21 AM
ATVracr's Avatar
Mast has the best heads out there!
From mild to the best race heads on the market.
Old Nov 25, 2010 | 11:36 AM
ATVracr's Avatar
No way the Mast heads are $2,000 more..... here you go $3,000 for a set ready to bolt on.
P/N 510-302
Retail: $1499.99 ea
Flow Data w/4.000" Bore Plate
Lift Intake Exhaust
0.100 74 61
0.200 146 119
0.300 222 188
0.400 282 219
0.500 330 236
0.600 360 251
0.700 372 260
I have owned or seen all these heads on the dyno and the Mast/old ETP heads made the most HP and are superior quality.
Old Nov 25, 2010 | 08:22 PM
Jenson's Avatar
Wow this thread took off all the sudden. Yea the small 4.0" bore head is the one we are looking at, not the 3.9". This is also a "money is no object" type build. Those flow numbers look pretty dang good and we are talking about a .700-.720 lift cam. Thanks for the info.
Old Nov 25, 2010 | 10:33 PM
taman86's Avatar
P/N 510-302
Retail: $1499.99 ea
Lift Intake Exhaust
0.100 74 61
0.200 146 119
0.300 222 188
0.400 282 219
0.500 330 236
0.600 360 251
0.700 372 260
well like i said, when i was pricing them, it was back last year when that article came out and it was the 3.9" small bore heads also, so the pricing has come down some, 3200 ready to go to 3000. still 3 grand is very pricey, but if you got deep pockets then by all means, but for most of us who have to work for a living on 30-40k a year with a mortgage, car payments, car insurance for those cars that arnt paid off, etc. we dont have much left to spend. plus from what ive read, there have been alot of disappointed people that have bought these heads while using the correct cam specs. you would think that with those flow numbers and the ls3 intake that you'de be seeing closer to the 500 mark. these heads were designed primarily for larger bore motors unless you were strictly looking for ls3 power with having to transplant a ls3 into your f-body. cuz realisticly, 440 whp with an ls1 is pretty close to ls3 power.
Old Nov 25, 2010 | 11:16 PM
I was referring to the Hot Rod article that jimbo pointed out for me not the GMHTP article. The hot rod article was much more in depth as far as heads go. It had about 13-14 different sets of heads from as cast to CNC.
Old Nov 25, 2010 | 11:20 PM
This was on their project motor that was once a 364 correct? I think it made in the neighborhood of 550 at 6.2l and when they stroked it and did the head article in December it made anywhere from 600 with some heads and over 620with other heads. Much more than a H/C/I stock cubic inch LS1. This was with the same 230ish duration cam that they had when the motor was 364 cubic inches. They even said after they stroked it and did the heads test that it was a pretty small cam for the motor. After being stroked it was making peak power at 6k IIRC. Correct me if I am wrong please Jimbo and clear up the points I failed to miss. It was a very good read for those looking for a set of heads.
BTW hp numbers were on a engine dyno not at the wheels.
Old Nov 25, 2010 | 11:23 PM
http://www.hotrod.com/techarticles/e...est/index.html
Here is the article, I highly recommend reading it.
Old Nov 26, 2010 | 09:03 AM
Jenson's Avatar
Definitely a great read. This is not my motor. It is for a race car that requires stock style heads. The motor in the car is an LS9 so we must run rectangle port heads. The benefit of a 6.0l is a larger restrictor. Thanks again for the info guys
Old Nov 26, 2010 | 11:58 AM
I'd go with the GM performance parts CNC LS3 heads. Cheap and effective out the box. If you didn't have to run rectangle port heads, but they had to be stock style then the Pro Comp CNC 243's look very promising. Even having the smallest port volume out of all the heads in that shootout (215cc) they made the most peak power, even over TFS, AFR and Mast.
Old Nov 26, 2010 | 07:47 PM
Brian Tooley Racing's Avatar
I think the Pro Comp port volume was 219cc, and it's their own brand new casting, not a 243 casting. In a drag race, it wouldn't win due to low average torque, but it's impressive for the cost!
Old Nov 27, 2010 | 08:09 PM
Jenson's Avatar
It's not possible to get that much compression out of stock castings. We will have to be in the 45cc range.
