SDPC LS2 413 Which cam?
Old Nov 24, 2010 | 04:59 PM
ripinLS1's Avatar
Default SDPC LS2 413 Which cam?
Its a SDPC LS2 413 Need some input on a cam for this short block.This is the rest of my LS1 stuff Iam useing. FAST 102/102 Trick flow 220 as cast with 59cc 11:9:1 comp. Thanks
Old Nov 24, 2010 | 05:12 PM
Fbodyjunkie06's Avatar
Dedicated street car?
Old Nov 24, 2010 | 05:15 PM
ripinLS1's Avatar
Street/Strip
Old Nov 24, 2010 | 05:30 PM
I'm sure you already know this then, I'm not a cam guru, but if it we're mine I'd look for something like low .240's intake high 240's duration, maybe even low 250's depending on how much your willing to sacrafice in drivability. Are you going to be using the same 220's that are in your sig? The Trick Flow Heads flow great so just about anything you throw at it is going to respond with 400+ cubes at that kind of compression too. I'd look for something around .61x/.62x lift and 111 or 112 LSA. Where is the meat of the airflow at in those heads, after .600 I'm guessing?
Old Nov 24, 2010 | 05:49 PM
ripinLS1's Avatar
Should I get with Patrick G. about the cam ?
Old Nov 24, 2010 | 05:58 PM
TransWS6Am's Avatar
I would, he's he best a specing out lsx cams......
Old Nov 24, 2010 | 05:59 PM
I would definitely do that. No doubt about it, IIRC he only charges 20 bucks for spec'n a cam for people.
Old Nov 24, 2010 | 06:23 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
We have quite a large selection as well as a custom cam service as well. Let us know! I have a few in mind right now really....
