MLS gasket and head stud kit
Old Nov 28, 2010 | 01:25 PM
Gordon0652's Avatar
Default MLS gasket and head stud kit
Soon i will be installing my heads on my LS7. I have noticed that it nearly impossible to install the gaskets when the studs are in the block.
Any tips?
Old Nov 29, 2010 | 06:29 PM
Gordon0652's Avatar
Anyone? Gaskets get cought up on studs and it's a PITA to put on
Old Nov 29, 2010 | 07:10 PM
S10xGN's Avatar
Patience! Since studs are installed dry and finger-tight, if you really get frustrated just pull a row of studs, install the gasket over the remaining few, then reinstall those removed studs.
Old Dec 1, 2010 | 06:27 AM
Randy WS6's Avatar
If you dont let the MLS seperate while going over the threads and start evenly they will go on fairly easy, But like said above, just remove a few studs
