going to the junkyard. What motor?
You can find you a
LQ4
LQ9
LY6
for cheap, around $800-$1500 with reasonble mileage.... of course, less mileage, usually more expensive....
They have LS2's,LS3's,L92's but they are going to be a little more......
install the cam, follow proper procedures, assuming you have the know how(ptvc check,spring kit,pushrods,lifters, etc...) yada yada yada.......
drop it in and roll....
If you blow it, which I doubt, you'll only be out of $1500-$2500 vs $8000-$10000.... I will will take my chances, as long as they the junkyards keep filling up with the 6.0's+ etc..... I am not spraying or boost, so a stock bottom end is good for me... Alot of guys over do it and forge everything, but if your not using any power adders or trick stuff, just a N/A setup, a stock bottomend would be fine, but its up to you and your intent....
Now if you want something custom, etc... then look into getting one custom built by said HKE or whoever you chose, but for a budget banger, it can be done..... If you got a more time than money...... But if you got the money, knock yourself out...
Bozz
The l92 and ls3 motors are great but they have a different intake and are dbw throttle body. You will end up needing a cable driven TB. The cranks are 58X tooth and the ls1 ecm is 24x tooth so you will need to convert that too. Also, check out LKQ for motors.
I'd like to use the L92 heads.
The Lq4 as a shortblock is only 9.4-1. Can an L92 head be milled safely to get the compression to 10.8-11? ( probably not)
If not, then It seems the LY6, L92 or Lq9 is the better option....Yes?
Also, all the lq4 motors I can find have over 150,000 miles on them. I would perfer not to tear apart the short block. How many miles are to many if I want to setup a heads/cam + 150 shot?
