LS3 heads Hollow valves question
Old Dec 5, 2010 | 04:48 PM
The stunningman's Avatar
Default LS3 heads Hollow valves question
I just eyeballed a set of LS3 heads (0821) and the distance from the top of the retainer to the tip on the hollow Intake valve looks to be greater than the standard exhaust valve. Visually greater... I did not measure the retainer height differences (they aren't mine). Just wondering whats changed?
Are the Intake valves longer or is the groove lower on the valve for some reason?
If the groove is lower then I would have thought there would be a few post about the spring heights not matching up.
Or if the valve is longer then the pushrod length would be different.
Old Dec 6, 2010 | 08:42 AM
Wow, no one else notice this?
Old Dec 6, 2010 | 09:19 AM
rsz288's Avatar
From memory GM reduced the intake base circle on the cam and extended the valve a little to address that. It was a while ago (3 years...) so memory a little dim.
Old Dec 6, 2010 | 11:51 AM
If that was the case you would need different length pushrods for the intake than the exhaust. Correct?
Old Dec 6, 2010 | 08:48 PM
https://ls1tech.com/forums/generatio...erent-l92.html
Old Dec 7, 2010 | 07:46 AM
rsz288's Avatar
Not really, the reduced base circle on the cam can be corrected by a longer pushrod or a longer valve. GM chose the valve as it wont get mixed up like running unequal length pushrods.
