GMPP LS3/L92 Hand Porting.
you should know that if you want to go really fast you have to pick and tune and adjust and carefully select the perfect parts for each piece of the total puzzle of a car - every car is different and everyone is going to set theirs up in different ways.
with that said you take a camaro making the same power as a goat and the camaro is probably going to go down the 1320 faster - the rearend is better setup for it from the factory and other things that add up - but you should already know that - piece for piece goats don't go down the strip as fast as f-bodies do.
i'm no where near someone who has a lot of experience on the subject but I do know enough to know when I don't know as much as someone else and I'll shutup and listen to them instead of trying to prove how cool I am with what I know.
