6.125 Rods.
Old Dec 12, 2010 | 11:32 AM
e-racer-ls-1's Avatar
Default 6.125 Rods.
Got my pistons,need to get a set of rods.Any input on the scat rods?Under $300 with A.R.P. bolts.6,500 R.P.M chip glued in place.Street car that might see the track once in a while.Tell me what you are running!Thanks to all.
Old Dec 12, 2010 | 01:19 PM
TransWS6Am's Avatar
You get what you pay for. Callies compstar h-beam here.
Old Dec 13, 2010 | 04:26 AM
Default Rods
I am not trying to cheap out,just putting my money where it needs to be.The compstar rods are nice,not in my price range.Thanks.
Old Dec 13, 2010 | 07:10 AM
Busted Knuckles's Avatar
I've run the Scat ProComp (poor choice of names for Scat) with great luck. The big end is stroker clearanced, beams are polished, yada yada. They look a lot like the old Lunati Pro Mod. I wouldn't hesitate to use 'em. Make sure the part number ends in -7/16, they do make others with a different design.
Old Dec 13, 2010 | 05:18 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
We run a lot of callies compstar rods and have never had an issue. Right now we have them on sale at $540, give us a call if you need a set we have them in stock.
Old Dec 16, 2010 | 11:07 AM
serpentnoir's Avatar
I called SCAT last night. The Tech indicated the Pro comp I-beams with ARP 7/16" bolts are good to 800hp.
Took 2 minutes to get that answer, versus what you typed which has absolutely no tech whatsoever.
Old Dec 16, 2010 | 02:11 PM
RENE'S RAGE's Avatar
Callies Compstar crank and rods.
Old Dec 16, 2010 | 07:15 PM
TransWS6Am's Avatar
Not trying to start a debate here but compstar is higher quality than scat (i mean come on SCAT is another word for ****), obviously theres higher quality than compstar also, so theres no need to point that out. i was just saying i would pay a couple hundred more for some compstars.
Old Dec 16, 2010 | 07:33 PM
Always2Slow's Avatar
The compstars are well worth the money no doubt in my mind and would be first choice, but for just a street car the scat will be fine just double check all the clearances and measurements.
Old Dec 18, 2010 | 05:19 PM
Scat Pro Comp 6.125". 607 grams.
Old Dec 18, 2010 | 09:39 PM
Default Rods
Thanks for the pic's,I am going with the same rods.
Old Dec 19, 2010 | 10:11 AM
LS1 BU's Avatar
I have run the scat I beams for about 4 years without any issues. I used the 6.125 rods in my 348 then reused them in my current 416 l92. Have been over 7,000 rpms many times with both motors. I think they are good rods. Nice thing is I didn't have any clearance issues with them in my stroker.
Old Dec 19, 2010 | 10:22 AM
Default Thanks
Still the rods I might buy,looking at some howards rods.Thanks and your car looks great!
Old Jan 20, 2011 | 11:37 PM
Default SCAT Pro comp rods + 4" stroke = plenty of clearance
Clearance to LS2 block on #1 and #2 rods.
Fancy camera, no macro lense = crappy pictures.
Old Jan 20, 2011 | 11:45 PM
I looked at Howards also. Their PM rod is far superior to GM stock rod but I couldn't find it in 6.125" length and they are relatively expensive. I wish someone would produce a PM rods for aftermarket at a decent price. The cracked cap technology is far ahead of dowels.
Old Jan 21, 2011 | 06:47 AM
^ dowels are working fine for 99.99% of us...and they can be resized during a rebuild, cracked cap are junk once they're out of round spec.
Old Jan 21, 2011 | 09:40 AM
Callies Performance's Avatar
Thank you all for the support. Clearly, as see in the attachment, this is not a Apples to apples comparison! We are working on a cheaper LS rod, however, with a good deal from one of our many dealers, we are only 250 apart on a H beam!
Adam @ Callies
Old Jan 21, 2011 | 10:45 AM
I don't see why they can't be re-honed then use an oversize bearing.
Old Jan 21, 2011 | 10:52 AM
Adam @ Callies
Make sure the bolt head clears the block without clearancing on a 4" crank. That was one of my criterias for buying the SCAT rod aside from the low price.
The jist of all this I guess is there are lot of us who build 500~600hp motors and don't need the beef/weight of a 1000hp rod. It's the same reasoning I used when buying your LSC crank. I am very happy with the quality. Work of art.
Old Jan 21, 2011 | 10:57 AM
No worries, Like our H's and I's they will be "Stroker Ground"
