top end question
From a 6.0 LS2 internal engine with a 244 250 .610 lift cam....full bolt ons.
The switch:
FROM ported fast 92/90 combo with say stock ls6 heads...
TO
Stock L92/L76 head/intake combo?
From what I see the l92 heads flow a LOT better.
What about the lift of that cam witll that be a problem? I ask because I notice a lot of smaller cams are usually used in that setup.
Will the springs swap over?
If that cam fits, you certainly will be need to be careful if you deviate from the stock compression.
