Head Gasket? LS2 w/ LS3 Heads
I can use a LS2/L76 gasket when installing LS3 heads (the L76 is a 6.0 w/ L92 heads btw)
from searches I've also read:
Use must use a LS3/L92 head gasket with L92/LS3/L76 heads as the gasket will hang in the chamber.
Can someone set the record strait?
Too me it seems using a LS2/L76 gasket should be fine, as the L76 uses these damn heads!
I spent $75 for LS2/L76 gaskets and want to know if I should send them back.
Help a brother out, thanks.
