will these l92 heads work with my setup
i have a set of 62cc l92 heads and a 415 stroker and im wondering if these heads will work without ptv clearence problems. i want to use a good sized cam that is 650 inch lift or less. and what compression ratio do you think ill make.
LS1TECH & Trucks Sponsor
I assume since you have a stroker motor you have aftermarket pistons with a valve releif. What size if the valve releif on that piston? People will need to know that in order to help you get the correctly sized cam. Typically any size of valve relief in these motors gives you enough room to do what you want as far as cam size goes but it is always good to know what you are working with.
