budget lq4 stroker
Old Dec 17, 2010 | 05:56 PM
mytjrox's Avatar
Default budget lq4 stroker
I am in the process of putting together an 2005 lq4 for a truck i am building and have some questions reguarding stroker kits. it seems there are alot out there in a wide range of prices whats the best bang for the buck?? i am wanting to go to 408 cubes. i have already purchased a gmpp hot cam with lifters and valve springs if that matters for the crank. thanks for the help in advance.
Old Dec 17, 2010 | 07:55 PM
slowride's Avatar
If it's just NA run the cheaper compstar crank and Scat I beams. Should be under 1K for both (more like 7-800 if you have some hook ups)
Old Dec 17, 2010 | 09:04 PM
mytjrox's Avatar
any vendors on here have those products
Old Dec 18, 2010 | 08:58 PM
BOBS99SS's Avatar
Captain Double Post
Is that a ls6 hot cam kit? in a 408 I would run something bigger
Old Dec 19, 2010 | 07:37 PM
xdanny510x's Avatar
Go with eagle crank and rods if u on a budget!
Old Dec 20, 2010 | 08:26 AM
Callies Performance's Avatar
Default Compstar LSc
Run the 5140 LSc forged Compstar crank $544.00
and Compstar 6.125 H beam rods $607.00
$1151.00
-Adam @ Callies
